no power to windows or radio HELP !!!!!! - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-18-2006, 03:18 PM Thread Starter
wvh187's Avatar
Date registered: Aug 2006
last night i was working on my car tryint to fix the cruise control i installed the new switch and it still did not work... so i put everything away then today i went to me car and started it and my windows dont roll down and my radio does not work... Everything but the radio and windows work... i checked all the fuses i have been sitting here tryin to look for bad connections but i cant find anything ... can anyone please help me if they have had this problem or know what to do ..... HELPPPPPPPPPPPP
wvh187 is offline
post #2 of 4 (permalink) Old 10-18-2006, 05:17 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
I don't know what kind of car you have, but that may prove helpful. Also, my best guess is either (1) you unplugged something, either consciously or unconsciously, and forgot to plug it back, or (2) something got shorted. It really sounds to me like #2. How many fuse boxes does your car have and did you check every fuse in each box?
MarcusF is offline
post #3 of 4 (permalink) Old 10-19-2006, 09:39 AM
gold300grey560's Avatar
Date registered: Nov 2005
Vehicle: 300se 560sel
you may want to check the voltage of the capacitors located in the fuse box. if not the capacitors, you may have a dodgy relay...i had non-working windows and £23 spent at the stealership provided me with a new relay and capacitor which solved the problem. also check that the fuses don't have hairline cracks, or oxidisation of the ally of the fuses. change the fuses to the copper type. as a last measure disconnect the battery, wait 30 secs and the re-connect. good luck.
Just look at that car, don't it look great just sittin there?
gold300grey560 is offline
post #4 of 4 (permalink) Old 10-19-2006, 01:01 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
As MarcusF indicated, model/year would be helpful.
GeeS is offline
    no power to windows or radio HELP !!!!!! wvh187 W201 190-Class 6 10-19-2006 09:16 PM
    help no power to radio or windows wvh187 Audio & Telematics Forum 0 10-18-2006 03:17 PM
    power windows 230emercedes General Mercedes-Benz 8 08-15-2005 07:30 PM
    power windows..... barberhauler W123 E,CE,D,CD,TD,TE Class 2 08-05-2005 05:47 PM
    Power windows !!!!!!!!!!!!! CEOG G-Class 1 08-04-2005 04:13 PM
