Diesel Smoke - Add ATF - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-18-2006, 10:40 AM Thread Starter
Buffaloajax's Avatar
Date registered: Oct 2006
Vehicle: 1980 300TD Wagon
I have a 1980 300TD Wagon and the gentleman I bought it from ( who had 8 ) said the way he keeps it from smoking was to put, I believe he said, ATF ( he had a thick accent ) - which I'm guessing was Automatic Transmission Fluid. Can anyone verify this for me and does it work?
Buffaloajax is offline
post #2 of 3 (permalink) Old 10-18-2006, 05:13 PM
Kajtek1's Avatar
Quoted: 1068 Post(s)
ATF was old remedy for cleaning the injectors and prevent fuel gelling in low temperatures.
It was used in those times, when in cold weather they started diesels with newspaper burning in the front of the intake.
Today nobody use ATF anymore, unless he wants to dispose ATF. Diesel engine seems to burn everything. One guy admitted putting used engine oil into his truck as a way of disposal.
I used to have 83 tdt and the "diesel purge" I bought on ebay helped to clear the smoke on it. Did zip on my CAT.
Kajtek1 is offline
post #3 of 3 (permalink) Old 10-18-2006, 09:53 PM
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
Quoted: 2 Post(s)
Prolonged, frequent use of ATF in diesels, in high quantities has been known to cause injector coking.
If you want to keep it from smoking, just give it an italian tuneup every now and then. That means a full, pedal down to the floor takeoff to about 65-70mph. The heat generated will clear out the carbon, and diminish smoke. Also make sure you're using a good diesel rated oil. Shell Rotella 15W-40, and Chevron Delo 400 come to mind.
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline
    ATF in diesel fuel? barberhauler W123 E,CE,D,CD,TD,TE Class 32 10-06-2011 03:06 PM
    Why Regular Use of ATF shouldn't be used as a diesel fuel additive H-TownBenzoboy W123 E,CE,D,CD,TD,TE Class 0 10-27-2005 04:56 PM
    ATF instead of Diesel? polo35 W124 E,CE,D,TD Class 2 09-08-2005 02:23 AM
    ATF Dipstick/ ATF Fluid Change and Electronic Transmission JNLeChevet W140 S-Class 1 03-02-2005 07:30 AM
    Diesel Smoke Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 2 08-12-2002 09:34 PM
