Opinions - Jack Stand location - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-12-2006, 01:28 PM Thread Starter
Date registered: Oct 2006
Vehicle: 1998 E320
Hi y'all. I am posting this on the General forum because I am thinking pretty much every model may have the same rubber mounts underneath. How safe is it to use jack stands on the four rubber mounts beneath and just behind/in front of the front/rear wheels? My 1998 E320 has a seperate location for the factory jack to be used to change a spare (it is located above the rubber mounts). I am worried about using standard jack stands with a "V" notch on the top (if they came with more of a cupped top that would be great). I am thinking that the car could rock on the rounded rubber mount using said stands. Perhaps I am just paranoid, and there is no safety issue, but I just want some opinions. I am planning on taking Texas-Patrick's advice on replacing my own engine mounts and will need to raise up the front of the car to gain better (and much needed) access.
Thanks all!
Texas is offline
post #2 of 3 (permalink) Old 10-13-2006, 07:08 AM
Date registered: Aug 2005
Vehicle: 2003 S430 Sport Edition
If you want to change the motor mounts your self, it is better to purchase two jacks stands. And place it up front. I think you'll need a third one to hold your engine up once you took off the mounths.
Curacao is offline
post #3 of 3 (permalink) Old 10-13-2006, 06:10 PM
Date registered: Jul 2006
Vehicle: 1990 300E
Get a set with wide tops and place them under the unibody "frame" area. I do this all the time and it is rock solid. The rubber gives a bit, I like it solid.
my90300E is offline
    We stand down, they stand up, and rip off everything in sight FeelTheLove Off-Topic 0 08-26-2006 09:39 AM
    Rear Jack stand location Michael Pillay W126 S,SE,SEC,SEL,SD,SDL Class 9 08-04-2006 02:14 AM
    Jack and Jack stand recomendations Steve230 R170 SLK-Class 16 07-06-2004 09:39 AM
    Is there a specific height for a jack stand to be in order to UniquelySanFrancisco W163 M-Class 8 05-26-2003 07:07 PM
    What weight rating of jack and stand should be used for ML? noelb W163 M-Class 14 04-11-2002 09:52 PM
