Help! My C 240 won't start - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 10-09-2006, 07:06 PM Thread Starter
Benzigirl's Avatar
Date registered: Oct 2006
Vehicle: C 240
Parked my car the other night and it seemed just fine. Tried to start it the next morning and it will not start. The console lights up and the radio, lights etc all work but it has no juice when I turn the key. If anyone has any suggestions I would really appreciate it. It's getting towed to the shop on wednesday. :
Benzigirl is offline
post #2 of 14 (permalink) Old 10-09-2006, 07:12 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 737 Post(s)
Battery is the first thing to look at...
GeeS is offline
post #3 of 14 (permalink) Old 10-09-2006, 07:20 PM Thread Starter
Benzigirl's Avatar
Vehicle: C 240
My brother in law came over and tested the battery and it has 12 1\5 volts which is were it should be. Any other suggestions?
post #4 of 14 (permalink) Old 10-09-2006, 07:26 PM
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
Volts on battery is not a good test
Battery should be tested by measuring amps under load (while you trying to start the car)
Easiest way is just try to jump start the car.
Kirill
Kirill is offline
post #5 of 14 (permalink) Old 10-09-2006, 07:30 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 737 Post(s)
^^^^ What he said.
GeeS is offline
post #6 of 14 (permalink) Old 10-09-2006, 07:33 PM Thread Starter
Benzigirl's Avatar
Vehicle: C 240
Thanks alot, I will try to boost it in the morning.
post #7 of 14 (permalink) Old 10-09-2006, 07:33 PM Thread Starter
Benzigirl's Avatar
Vehicle: C 240
Thanks for the info.
post #8 of 14 (permalink) Old 10-10-2006, 07:35 PM
Canadian_Yeti's Avatar
Vehicle: 2003 C230K Evo
crankshaft position sensor is a good possibility
Canadian_Yeti is offline
post #9 of 14 (permalink) Old 10-10-2006, 08:04 PM
I would like to know what the problem is myself. I have a 95 S 500 coupe 140 and it does the same thing. for no apperant reason it will not start ( crank) . Everthing works. I have had the battery tested as well as the starter and alternator. It has something to do with the starter lock out system.
Harvey Bee is offline
post #10 of 14 (permalink) Old 10-10-2006, 08:05 PM
I hope someone has the answer
240 CD !!!!! rib W123 E,CE,D,CD,TD,TE Class 0 02-10-2006 03:27 AM
sl500 cold start fine-short trip park restart rough idle hard start?? dpol1835 R129 SL-Class 7 01-02-2006 06:33 AM
Cold Start? hard to start after temp drops Prissy6990 W126 S,SE,SEC,SEL,SD,SDL Class 4 02-15-2005 06:51 PM
Hard start or second start when warm high hc level-- beware major expense Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 1 07-03-2004 06:23 PM
Should my 1989 190e start in 2nd gear unless floor it from start? Guest (MBNZ) W201 190-Class 5 08-01-2002 12:27 PM
