Can I Install A Remote Starter On 1998 E320?? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-08-2006, 10:59 PM Thread Starter
Date registered: Oct 2006
Can I Install A Remote Starter On 1998 E320?? As we all know, mercedes has the little coded way of starting a car. Has anyone with a mercedes close to my year been able to install a remote car starter??? Thank you for your time.
SomeGuy07 is offline
post #2 of 10 (permalink) Old 10-09-2006, 01:40 AM
gsm-decode's Avatar
Date registered: Apr 2006
Vehicle: Sl500 1997
I dont think u can do that on that model
gsm-decode is offline
post #3 of 10 (permalink) Old 10-09-2006, 04:13 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
The idea of the smart key is that one cannot get the engine running without the correct key. I guess you do not want to leave the key in place and have a remote starting device turning the key (not a good idea on a KG car at least).
My main point of replying though was to mention that in my home country it is illegal to let the engine run on idle for more than 2 minutes (in traffic or not). Except if the temperature is, I think, below -15 degrees Celsius, then max 4 minutes. This is for the environment, to reduce pollution. The popularity of remote starting devices in the US and Canada is not seen too well, especially after suing car manufacturers about environmental issues.
Diesel Benz is offline
post #4 of 10 (permalink) Old 10-09-2006, 08:15 AM
Vehicle: Several MB's
I had a remote starter installed on a 1998 E430. It worked for a while and then , according to the MB service advisor, it completely screwed up the ECU to the point where the car would not even run. The dealer had the remote starter removed and reflashed the ECU and all was well. I would check it out before you havbe it done.
Lou K
Several And various Autos
Lou K is offline
post #5 of 10 (permalink) Old 10-10-2006, 08:58 AM Thread Starter
Lou K, 2 days ago u mentioned how you were able to successfully install a remote starter on your 1998 e430. Could you tell me please which starter you used (brand & model)??? Also, what did you tell the MB service advisor or what did he tell you in order to correct the prob?? Thank you.
post #6 of 10 (permalink) Old 10-10-2006, 09:29 AM
I do not recall the brand. The starter had to be removed and the ECU reflashed. The remote went back to the installer.
Lou K
Lou K is offline
post #7 of 10 (permalink) Old 10-10-2006, 09:47 AM Thread Starter
oh...so you weren't able to successfully install a remote starter? I geuss i misunderstood you. I thought you said after the ECU was reset, the remote starter worked fine.
post #8 of 10 (permalink) Old 10-10-2006, 02:53 PM Thread Starter
So its basically a done deal that a remote starter cant be installed on a Mercedes after like...1997
post #9 of 10 (permalink) Old 09-10-2016, 05:28 PM
Date registered: Sep 2016
Vehicle: 1998 E320
hey just seeing if theres an update on this, did you install remote start? I have a 98 e320 and I'm considering doing the same thing, no problems, just want the feature. I talked to a mechanic about having it done by a pro and he said the wires might burn out and wouldn't do it, but i haven't heard of this problem in any of my (five months) of research.
Sydney Lee Cagle is offline
post #10 of 10 (permalink) Old 09-10-2016, 10:39 PM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 449 Post(s)
If you know of a way to remote start a EIS equipped Benz, I'm all ears.
Afaik there's no way.
--1998 MB E300TD 285k
--1997 MB E320 198k
--2004 Dodge Ram 5.7L 212k and holding (damn gas guzzler)
--2011 Suzuki DL650 44k
--1997 MB E320 161k. SOLD...loved that stupid car.
--1998 MB ML320 207k. SOLD, thank heavens!
Deplore is online now
    Remote starter Cleveburg Audio & Telematics Forum 2 05-31-2005 12:02 PM
    Remote starter lnguyenh R129 SL-Class 7 11-24-2004 06:53 PM
    remote starter ToMmEeHBeNz W163 M-Class 9 01-12-2004 07:45 AM
    Remote Starter Ratso W163 M-Class 29 01-01-2004 07:42 PM
    Has anyone install a remote starter in the SLK? Where did you get the Loi R170 SLK-Class 7 09-25-2003 08:51 AM
