supercharged or turbocharged - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-08-2006, 01:48 AM Thread Starter
AMG NUZI's Avatar
Date registered: Jun 2004
Vehicle: ML55AMG
my friends and I argued this topic all night.
would a supercharged 55 be faster? or
would a turbocharged 55 be faster?
can you guys answer in a short explaination?
pro's and con's. thanks.
AMG NUZI is offline
post #2 of 5 (permalink) Old 10-08-2006, 06:56 AM
StreekG's Avatar
Date registered: Oct 2005
Vehicle: 1978 C123 280CE, 1988 500SEC, MY10 W204 C200 CGI
Quoted: 43 Post(s)
Send a message via MSN to StreekG
Well being an auto the 55 would be better suited for a Supercharger, but im not sure which would be faster though. My theory would be that if you had a supercharged version and a turbo'd version both running at the same psi, a supercharged would go better because the power is always available. The turbo kicks in from certain rpms right? Can anyone clarify?
Cons of the turbo is the lag on the auto.
Pros of supercharger, its like having NA, power is all there.
'88 500SEC M117.965 - Feind Stage II Cams, Adjustable cam gears, Dkubus 2000rpm Hi-Stall torque converter, Full S/S Twin 2.5" Magnaflow exhaust, Eibach Springs, Bilstein B8 Sprint Shocks, Dkubus thick rear sway bar. Running Dkubus FrankenDPR CIS-E fuel management
StreekG is offline
post #3 of 5 (permalink) Old 10-08-2006, 08:16 AM
Kajtek1's Avatar
Vehicle: w211 E320 wagon 4M / Bluetec / Ford SD. Seeking affordable diesel pushmower
Quoted: 1044 Post(s)
My understanding the supercharger, having much more power available can be set up much higher, than turbocharger.
Read the thread about drag racing, where supercharger draws more than 300 HP.
When it comes to comparing real vehicles, it all depends what engineers put in them. Just because they might, doesn't mean they did.
Kajtek1 is offline
post #4 of 5 (permalink) Old 10-08-2006, 02:06 PM
Date registered: Oct 2006
Vehicle: 2005 SL500 and 2005 E320 CDI
Send a message via AIM to SinCitySL500
Having owned both a turbocharged and supercharged car I can offer a little light on this subject.
First off, it depends on what kind of supercharger. If its a centerfugial supercharger (Vortech, Procharger type), it still has to spool like a turbo. It also depends on what kind of turbocharger(s). If its a large single turbo, lag will be much greater than two smaller turbos. I have a twin turbo Nissan 350Z race car that reaches full boost at ~2300 rpms with two Garrett 530bb turbochargers.
If both cars were identical weight, model, and whp, one with a roots type blower, and one with a turbocharger, I would give it to the supercharger 9/10 times. The only time it would be even would be in a race where the turbo car starts out in full boost and never leaves full boost.
2003 Mercedes Benz SL500
20" iForged Daytona
2006 Mercedes Benz E320 CDI
SinCitySL500 is offline
post #5 of 5 (permalink) Old 10-09-2006, 10:15 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Makes no difference.
Of course the units have to be same capactiy to start with.
Theoretically, the turbocharger is driven with "free" energy, while the supercharger uses engine power to drive it, just like your alternator.
BIG problems with turbocharger heat, however.
Kent Christensen
'07 GL320CDI
lkchris is offline
    420 turbocharged Mark420 W126 S,SE,SEC,SEL,SD,SDL Class 9 04-13-2005 10:07 AM
    Turbocharged 500sel PimpinBenzo W126 S,SE,SEC,SEL,SD,SDL Class 13 03-07-2005 08:51 PM
    Supercharged Blokhus R170 SLK-Class 10 01-30-2005 06:12 PM
    190E Super/TurboCharged Blackbenz W201 190-Class 4 02-24-2003 10:48 PM
    98 SLK 230 SuperCharged or TurboCharged? Jason Hu R170 SLK-Class 8 12-27-2001 08:12 PM
