Dealer service:BG Fuel/Air Induction System Clean-up Service - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-07-2006, 06:54 PM Thread Starter
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 78 Post(s)
Has anyone done this? The dealership quoted me close to $200. I dont see how it is any better than a $5 bottle of Techron Chevron.
Michael Pillay is offline
post #2 of 3 (permalink) Old 10-07-2006, 07:00 PM
Kajtek1's Avatar
Quoted: 1070 Post(s)
Doesn't Chevron sell the gasoline with cleaner in it already?
Where did you fill up? I usually fill up at cheapest stations and never had dirty injectors.
Kajtek1 is offline
post #3 of 3 (permalink) Old 10-07-2006, 08:25 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
Ages ago when I was a tech (non-MB), this was a real service that made a noticeable difference. However, fuel quality has improved dramatically since then (late 1970’s). Currently, it’s been my experience that if good quality fuel is used (what’s commonly called Top Tier gasoline), an injector service isn’t needed for several hundred thousand miles. Lower tier fuel will work just fine in a car. But the long term results of using lower tier fuels are lousy fuel injector spray patterns, which is what the injector service is supposed to clear up. A bad injector spray pattern can result in lowered fuel economy, marginally reduced power levels, some cylinders running rich, while others run lean, reduced O2 sensor life, and reduced catalytic converter life. I’m sure there are other consequences, but those are the ones that immediately come to mind.
MarcusF is offline
    I took it in the A$$ at the dealer for a service B Kilbane C208/A208 CLK-Class 15 10-19-2005 06:55 AM
    Reseting the flexible service system. Does the service manual lie once again? wallywalt R170 SLK-Class 0 09-09-2005 11:02 AM
    Air Induction System GOAT W163 M-Class 3 03-06-2005 12:26 PM
    B Service, Excellent dealer service sosh W163 M-Class 3 03-01-2004 08:32 AM
    Geoff and's the second "version" air induction system mods. without................... Linh R170 SLK-Class 24 03-25-2002 11:18 AM
