ECU Removal from CLK430 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-04-2006, 01:38 PM Thread Starter
Date registered: Oct 2006
Have a 2001 CLK430 and want to have the ECU removed to be sent to inMotion to be flashed. I can't find the directions in this forum. Can anyone help?
netpounder is offline
post #2 of 2 (permalink) Old 10-05-2006, 06:11 AM
JD300CE88's Avatar
Date registered: Dec 2004
Vehicle: '06 ML350, '88 Testarossa
First disconnect the negative battery terminal located at the right rear under your trunk cover.
Under the front hood and on the passenger side closest to the windshield, there is a black cover. Remove the cover and unplug the connectors, then unscrew the ECU from its mounting bracket and remove it.
Hope this helps.
JD300CE88 is offline
    Ecu Removal ASSIF B C208/A208 CLK-Class 14 01-25-2012 09:48 PM
    ECU Removal from CLK430 netpounder C208/A208 CLK-Class 6 10-08-2006 05:48 PM
    ECU removal Badbruno C219 CLS-Class 1 04-24-2006 03:27 PM
    CLK430 w208 Engine cover removal Jackie411 General Mercedes-Benz 0 06-06-2005 05:00 AM
    Headlight removal,(bumper cover removal?) racingdave W203 C-Class 5 01-13-2005 10:05 AM
