ECU problem in my 2003 ML320 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-30-2006, 12:00 AM Thread Starter
Date registered: Sep 2006
Vehicle: 2002 ML320
I bought the 2003 320 few months ago. Performed well in the first few months then recently it started developing shifting problems. Basically it will stop shifting and lock itself in the lowest gear. The lights in the dash indicating what gear the car is in will be blank. When the problem occurs, also the Check Engine, the ABS and the ESP lights will be on. I told it to the service centre. They hooked it up to the computer and couldn't tell what was causing the problem. They reset the ECU and it worked for couple of days then locked itself in lower gear again. Now they tell that the ECU has been water damaged and will need replacing. I am not sure how can the ECU be water damaged because I live in a dry climate (Dubai). Although I traveled overseas for a month and the car was getting washed every second day during this period. Maybe water got in somehow and damaged the ECU because the car just sat stationary for a month. Did someone had a similar problem liks this before? I find it difficult to accept that Benz will have such a bad design for the location of the ECU that it can get damaged just by washing the car. Could it be just a software problem? Although they did reset the software twice already. I am getting quoted more than $2,000 for the parts. Ouch
karmannghia60 is offline
post #2 of 3 (permalink) Old 09-30-2006, 01:32 AM
Date registered: Mar 2006
I'm no expert but i highly doubt that ECU has had water damage to it.. ECU is sealed water tight i believe...
s430owna is offline
post #3 of 3 (permalink) Old 09-30-2006, 09:24 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 78 Post(s)
You might want to check out the w163 forum. Maybe a search will of that forum will help.
Michael Pillay is offline
    PULLEY+ECU for Slk 200K evo special edition year 2003 molder2k R170 SLK-Class 2 08-22-2006 06:02 AM
    wanted 2003 sl 500 ecu cnterline For Sale/Wanted/Trade/Giveaway 0 04-13-2006 06:41 PM
    2003 cl 55 amg - is it worth getting the ecu reprogrammed? markwojo General Mercedes-Benz 1 02-09-2006 09:11 AM
    Where is the ECU on a 2003 SL55? JosanK R230 SL-Class 7 02-23-2005 02:13 PM
    Resetting ECU? WIll it cure starting problem? ramorris R170 SLK-Class 2 07-16-2004 01:28 AM
