Possible Mass Airflow Sensor ripoff? - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 10-30-2015, 04:44 PM
TJC
Date registered: Oct 2006
Vehicle: 2001 E320
Hi Greg,
I am having a challenge with the MAF. I have a 2001 W210 e320. About a year ago in Big Bear, about 7,000 feet above sea level, the BAS/ESP light came on and throttle response disappeared. After stopping and restarting the car behaved normally. I was curious why the car had altitude sickness, but didn't give it much thought as the problem ended at 4,000 feet. Now it is happening at sea level. I am getting a code of P0221 along with the BAS/ESP light and zero throttle response. Restarting solves the problem temporarily. I have refined the conditions for the error: 25-45 mph and partial to no throttle pedal. It seems to happen more readily when the engine is warm. I have a recent oem replacement of the TPS, the brake light switch is fine. Can this be a MAF sensor in the throttle circuit? I'm trying to figure out what component in the system would behave differently in the thin air/low pressure high altitude vs. thicker/higher at sea level ... then deteriorate to malfunction at sea level too. The only suspect I can think of is the MAF. If so, what supplier of inserts have you seen supplying quality parts at low cost?
Your direction is appreciated.
TJC is offline
Possible Mass Airflow Sensor ripoff? (Sticky?) BY Gregs210 JOE55 W210 E50 AMG, E55 AMG 5 10-18-2006 11:12 AM
New MASS AIRFLOW SENSOR MAF AIR MASS METER $1 97e320auto For Sale/Wanted/Trade/Giveaway 2 04-22-2006 03:56 PM
Mass airflow sensor in C230 samgupta General Mercedes-Benz 2 12-29-2005 06:39 AM
Mass airflow sensor install. supersparker C208/A208 CLK-Class 2 06-10-2005 07:04 AM
i didnt have to buy a mass airflow sensor!!!! seckid R170 SLK-Class 6 08-16-2004 09:06 AM
