replace fuel line with hose? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 09-26-2006, 07:06 AM Thread Starter
Date registered: Jun 2006
Vehicle: 81 Blue 300SD
Question replace fuel line with hose?
I need to replace my fuel line that runs along the underside of the vehicle (85 300TD). It seems to be leaking in a couple places, specifically where it's mounted to the body. I'm not sure if it's the return or supply, so I will probably replace both.
Can I use some kind of hose instead of trying to get a fuel line that I will need to bend and fit like the other one?
Another alternative would be to just cut out the bad sections and replace them with a short piece of hose. What would I use to cut fuel line?
Thanks
Dan
muchocheko is offline
post #2 of 9 (permalink) Old 09-26-2006, 07:18 AM
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
the hose have to be rated for fuel, or fuel will start to dissolve it and you'll get little pieces of rubber into your engine. - not good.
Kirill
Kirill is offline
post #3 of 9 (permalink) Old 09-26-2006, 11:49 AM
Date registered: Oct 2005
Vehicle: '82 380 SL, '82 300TD, '85 500SEC
Originally Posted by muchocheko
I need to replace my fuel line that runs along the underside of the vehicle (85 300TD). It seems to be leaking in a couple places, specifically where it's mounted to the body. I'm not sure if it's the return or supply, so I will probably replace both. Can I use some kind of hose instead of trying to get a fuel line that I will need to bend and fit like the other one?Another alternative would be to just cut out the bad sections and replace them with a short piece of hose. What would I use to cut fuel line?Thanks
Dan
Hi Dan. I'm going to have to vote: BAD IDEA on this one. Sorry for having to ask you to deal with hardlines, but the idea of running hoses along the bottom of the car...hoses filled with combustible fuel...is dangerous.
You can see that for the most part the lines you are worried about are basically straight, long runs from where they leave the rear axle area to where they enter the engine compartment area. IF you wish to use hoses to splice in new hard lines to the old hard lines...at least put the hoses up inside the rear axle area and up inside the engine compartment...NOT hanging down at the low point of the car... exposed to all kinds of road hazards!
So...sorry for being so concerned about your family trips in the wagon, but that's how I feel this morning. I'll stop ranting now. Have a great day!
Dave
Buy a tubing cutter where you buy the replacement lines...the auto parts store will no doubt have steel lines that will be close enough in size to the metric originals, so that you can go ahead and splice in the replacements...SAFELY! Sorry again. I guess I wasn't done ranting afterall.
daveward is offline
post #4 of 9 (permalink) Old 09-26-2006, 03:10 PM Thread Starter
Thanks to both of you.
Dave, that's exactly the kind of input I was looking for. I appreciate the info and concern.
I figured I would have to use fuel line instead of hoses but just wanted to make sure I wasn't overlooking a safe shortcut. I guess not.
Thanks again.
Dan
post #5 of 9 (permalink) Old 09-29-2006, 07:15 PM
Date registered: Jan 2004
Quoted: 30 Post(s)
Put a secton of hose in place of rusted out fuel line on my 240D about five years ago - still going strong.
Len
sokoloff is offline
post #6 of 9 (permalink) Old 09-29-2006, 07:41 PM
Kajtek1's Avatar
Quoted: 1163 Post(s)
Safety might be a concern, but I wouldn't exaggerate it.
But diesel runs with vacuum in the main fuel line. All available fuel hoses are rated for pressure, not vacuum. I used to have diesel motorhome with lot of hoses between two tanks, transfer switch, priming pump, water separator and filters. That thing was loosing the prime on regular basis, till I replaced all that mess with copper tubing and compression fittings.
If you engine is not loosing the prime, that means leaky pipe is return.
Kajtek1 is online now
post #7 of 9 (permalink) Old 09-29-2006, 08:33 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, Much.
I had to replace some fuel line in an old GTO many years ago, I bought brake line in precut lengths from the auto store. As I recall it bent fairly easily, those brake lines were 5/16" but they make it in several different diameters. For tight bends (particularly near the end of the line) you might need a tubing bender but thoseare pretty cheap. I used the same stuff when I replaced the AT cooler lines on the car which was a LOT more work.
Personally, were I you and I was going to keep the car, I'd take the extra time to "do it right". Knowing Murphy and his dastardly law, that's not a chance worth taking. At some point, all you might need is a little road debris and next thing you know, you're stranded and leaking fuel.
Kaj has a good point about the vacuum issue as well, so that's another concern.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #8 of 9 (permalink) Old 09-30-2006, 03:21 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
I have seen some articles about "polyetheline" tubing (spelling?) being used, it is semi- rigid, otherwise steel tubing is not that hard to work with, benders are cheap and you dont have to flare it. The fuel lines on my boat are all rubber but supported by a lot of clamps two engines/ generator/and two 75 gallon tanks. There are two clamps on every fitting such as valves to make the coast guard happy!
Peter Guenther is offline
post #9 of 9 (permalink) Old 10-05-2006, 01:53 PM
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
Bazzle is offline
    Fuel Hose Parts No. biondi W126 S,SE,SEC,SEL,SD,SDL Class 1 08-18-2006 12:45 AM
    metal fuel line CIS fuel injection 79 280se w116 rfitts46 W116 S, SE, SEL, SD Class 0 01-28-2006 03:37 PM
    Leaking fuel hose but which one? UmitATA W124 E,CE,D,TD Class 1 01-16-2006 08:47 AM
    Fuel Line Hose Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 4 03-17-2005 01:19 PM
    460 Locker Hydraulic Hose line Mark G G-Class 10 11-15-2004 02:08 PM
