No oil pressure - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-21-2006, 06:56 AM Thread Starter
Date registered: Sep 2006
No oil pressure
I just purchased a 1993 190e 2.3L, while test driving it I noticed that the oil pressure gauge was at 0 and remained there during the test drive. I pulled over cut the car off and checked the oil dip stick only to discover that the oil was a quart and half low. I added the oil needed, but the gauge never moved from 0. Not knowing what to do at this point, I obviously still went through with the buying trasaction. The car belonged to an elderly woman and it has 90,000 miles on it. She told me if there was a problem with the car to just return it to her (she doesn't want to sell a problem car to anyone) Should I be concerned, and what are my options at this point? Keep the car and repair it? What is the cost? Is it difficult to repair myself?
takeaction is offline
post #2 of 6 (permalink) Old 09-21-2006, 06:57 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Could be a bad gauge or a bad sending unit. Check the oil pressure with a mechanical gauge.
flyboyike is offline
post #3 of 6 (permalink) Old 09-21-2006, 07:53 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
The sending unit fails frequently, the issue probably lies there.
GeeS is offline
post #4 of 6 (permalink) Old 09-21-2006, 08:21 AM Thread Starter
How much is it to replace a bad sending unit and can I do it myself without a lot of engine tear down?
post #5 of 6 (permalink) Old 09-24-2006, 08:46 AM
Date registered: Jul 2006
Vehicle: 1990 300E
Remove the air filter housing, the oil pressure sending unit is near the oil filter. Hard to get to but not that bad. I would replace the oil level sending unit too as it should have showed low oil condotion. The oil level sending unit is on the pan left side near the oil drain plug......drain oil first!
my90300E is offline
post #6 of 6 (permalink) Old 09-24-2006, 08:24 PM
Kajtek1's Avatar
Quoted: 1070 Post(s)
Original unit can be expensive. For less, than $20 you can buy universal mechanical gauge from automotive story.
Kajtek1 is online now
    Oil Pressure jcmbz W140 S-Class 7 06-29-2005 03:37 AM
    Oil Pressure drop after oil change???? threepoint1415926 W124 E,CE,D,TD Class 22 05-12-2004 09:05 AM
    oil pressure/oil pump ...ronin W124 E,CE,D,TD Class 3 01-16-2004 03:27 PM
    Oil Pressure Special K W163 M-Class 3 09-13-2002 01:30 PM
    oil pressure and oil temp sender NickT G-Class 6 09-03-2002 09:42 AM
