Warm Starting Problem w210 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-19-2006, 02:47 PM Thread Starter
Date registered: Sep 2006
Talking Warm Starting Problem w210
Ok, I know we've seen this a few times before. I have a 97 E420 that has problems (had starting once the engine was warm. FIXED!!!. Aparrently there was a crack in the Charcoal cannister by the Fuel tank & the fuel shutoff valve was malfunctioning. Replaced all including the Fuel Tank Cap and no more starting problems.... $790.00 later at the dealership that is.
Hope this helps anyone who has the same problem.
Also had a small leak in the A/C Evaporator and the freon would last only 3-4 weeks. MB wanted $3500.00 to fix. Had a friend put in some leak stop (Superleak Stop $29.00), 2 Lbs of freon ($28.00), and some UV dye ($6.00) and so far so good. Do the math.
Peace.
Robin
niborstang is offline
post #2 of 2 (permalink) Old 06-15-2007, 02:51 PM
Date registered: Jun 2007
Vehicle: Mercedes Elegance E240 Avantgarde 1999 (UK)
starting problem
I've a E240 1999 with starting problem which I keep thinking is fuel related. When I put in more fuel it may start straight away or about 20 min later... Why would a new cap fix problem (as you stated)... Tested pump/relay all ok when it won't start there is no power to pump as if some sensor is telling system not to power up pump... Did your problem mainly happen on low fuel? Or did it not matter...
rjdesigns is offline
    190 2.6 warm starting problems kevinbentley For Sale/Wanted/Trade/Giveaway 5 10-06-2006 08:24 AM
    Starting Difficulties when warm stingray380sl R/C107 SL/SLC Class 6 09-19-2006 02:49 PM
    warm starting out then gets cold as i drive it flatfoot357 General Mercedes-Benz 2 02-19-2006 01:59 AM
    Problem starting my car when warm palsqito General Mercedes-Benz 1 07-20-2005 11:14 AM
    Hard starting when warm Pretorien W124 E,CE,D,TD Class 4 05-04-2004 12:03 PM
