Installation Problem with WIS/ASRA DVD - Page 3 - Mercedes-Benz Forum
post #21 of 25 (permalink) Old 03-09-2011, 01:20 AM
Date registered: Mar 2011
Originally Posted by Diesel Benz View Post
Which exact DVDs do you have or do you mean you have been using three different copies of the same DVD?
Did you use the first WIS DVD to install EWA NET? Your screen capture was not accurate enough to enable the DVD content being recognised.
Hi DB, sorry if my info is misleading. I m using Windows XP, hence compatible issue is not my concern now. Okay, in fact i have manage to install EPC net successfully.
Total i have 3 iso files: EPC_1_of_1_b1.iso, EPC_1of_2_a1.iso, EPC_2of_2_a2.iso
I follow all the instruction on how to install EPC, WIS as in PDF. I manage to install everything as in doc, until Steps 21, i stuck as below.
The WIS net base is installed in the same way as from the paragraph 24, you should just select the chapter WIS net. The launching is also similar."
This guide asked to install WIS net base in EWA admin tools, then click WIS net tab, when click Install, i get the msg and per screen shot, i've tried to browse all the iso files, but still no-go... hmm, do i need WIS net database to run WIS apps? Thanks bro
ahpek199 is offline
post #22 of 25 (permalink) Old 03-09-2011, 06:53 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
You do need the database before you get any documents from WIS or EPC.
Diesel Benz is offline
post #23 of 25 (permalink) Old 09-10-2012, 01:42 PM
Date registered: Apr 2009
Vehicle: 280s
i borrow this topic.i installed epc and wis.epc works fine but wis stucks.java load it and what new and screen appears,but it just starting module.how i fix it?thanks for any advise
juhizz is offline
post #24 of 25 (permalink) Old 12-13-2012, 09:55 AM
Date registered: Feb 2012
can any one tell me where to download the software from please
robchef is offline
post #25 of 25 (permalink) Old 01-21-2013, 04:01 PM
Date registered: Jan 2003
Vehicle: Chevy Suburban
Greetings ALL,
I had installed this SW about a year and a half ago on a VISTAx64 HP laptop and it ran flawlessly back then.
That Laptop lost it's graphics card so I ended migrating all the SW from the old hard disk to a W7x64 and all the software (never tested EWAnet, though) worked flawlessly (as it should).
Since then I had no need to run EWAnet, until yesterday that is.
I am greeted with the the messages as depicted in the first image below.
I do understand that with a new PC both the server name and the ip have changed. I made several attempts to find out how to point the SW to the new server/new IP, of course to no avail.
Next I attempted to reinstall the SW from scratch but I am greeted with the second and third images.
For the record, I am attempting to install the SW from the EPC_0711 DVDs.
I'd appreciate any and all help.
Thanks.
Name:	EWA error code.jpg
ID:	490989   Click image for larger version
Name:	ewa error code2.jpg
ID:	490990   Click image for larger version
Name:	ewa error code3.jpg
kayooh is offline
    EPC WIS&ASRA DAS Key Generator GDTm© General Mercedes-Benz 29 06-18-2015 02:21 PM
    Help 2 install WIS/ASRA Star Diagnosis DVD manual Teutone General Mercedes-Benz 21 05-01-2011 03:02 PM
    Help 2 install WIS/ASRA Star Diagnosis DVD manual Teutone W126 S,SE,SEC,SEL,SD,SDL Class 7 08-19-2010 02:41 PM
    WIS / ASRA / DAS mb230s G-Class 12 06-23-2010 12:49 PM
    WIS/ASRA plus EPC installed and running Teutone W126 S,SE,SEC,SEL,SD,SDL Class 8 07-18-2009 12:32 AM
