Installation Problem with WIS/ASRA DVD - Page 2 - Mercedes-Benz Forum
post #11 of 25 (permalink) Old 01-26-2010, 05:12 AM
Date registered: Apr 2006
Vehicle: '98 E430
Originally Posted by lauztuvas View Post
i try both disk but it is the same error come to my.i do all that was in my instruction.
I had the same issue on a Win 7 install. It is a permissions problem but I haven't figured out a fix yet....granting permissions didn't solve the prob
CurtB is offline
post #12 of 25 (permalink) Old 01-26-2010, 11:43 PM
lauztuvas's Avatar
Date registered: Dec 2008
Vehicle: Mercedes Benz c220 2,2l diesel 1996y
today i pass it step. i turn of system premision. start menu/control panel/ user acounts/turn user acount control then apears table. in this table will be ceked box. clear box and click ok.
lauztuvas is offline
post #13 of 25 (permalink) Old 01-26-2010, 11:49 PM
lauztuvas's Avatar
but now i have this problem:
http://s253696961.online.de/viewer.p...tljnge6es8.jpg
post #14 of 25 (permalink) Old 07-13-2010, 10:05 AM
Date registered: Jun 2010
Originally Posted by officerray View Post
It is possible to install DAS/WIS/ASRA/EPC software on an XP computer (Laptop or desktop - it doesn't matter) as long as the hard drive is within a specific size range. The current installation requires the hard drive to be at least 55GB but less than 100GB.
Daimler Chrysler have also incorporated some really quirky (security-based) requirements such as the number of partitions the computer must have, the type of partition (primary parttion / extended partition with logical drives) and also some specific windows registry keys that have to be manually created to set installation permissions beyond those outlined by winXP.
Finally, with the help of a key generator it's plain sailing. If you're not that familiar with computers then this may sound complicated but believe me it is not.
can u teach me how to do that?
fido_dido2110 is offline
post #15 of 25 (permalink) Old 07-13-2010, 10:17 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
I would not ask him, he is talking about hard drive restrictions that apply for SDS. WIS NET can be installed on any hard drive that has enough space to store the data. Windows7 may need some compatibility tricks, specifically if run on 64 bit mode, I'm not familiar with Windows7 installations.
And forget the old program manager approach. That must be from 1995 or how old was the guide from John Coupland that people still try to follow. If you cannot figure out the appropriate way, buy an up-to-date guide from John.
Diesel Benz is offline
post #16 of 25 (permalink) Old 01-10-2011, 05:57 AM
Date registered: Feb 2007
Did you ever get this working?
I too am struggling with installing on Win 7.
Works fine on XP machine, but cannot get WIS running on Win 7 laptop.
WIS database installs ok, but the red traffic light is on, stating that database not started.
Pressing the start button does nothing.
mr. shr is offline
post #17 of 25 (permalink) Old 03-08-2011, 12:57 AM
Date registered: Mar 2011
Exclamation How to install WIS database?
Hi Profs, would like to seek for help on how to install WIS database.
Under EWA Admin Tool -> WIS net tab ->
When i Click install, it will prompt me for the WISCD001. I've tried 3 DVD also unable to recognize. Anyone could help? Thanks.
Please refer to the screenshot below:
http://i6.photobucket.com/albums/y232/ahpek199/1-1.jpg
ahpek199 is offline
post #18 of 25 (permalink) Old 03-08-2011, 07:07 AM
Quoted: 39 Post(s)
Which exact DVDs do you have or do you mean you have been using three different copies of the same DVD?
Did you use the first WIS DVD to install EWA NET? Your screen capture was not accurate enough to enable the DVD content being recognised.
post #19 of 25 (permalink) Old 03-08-2011, 08:20 AM
SHAUNE55's Avatar
Date registered: Aug 2010
Vehicle: 2001 E55 AMG
Quoted: 4 Post(s)
Firstly as far as I know to make it work on Vista /windows7 you need to set up a virtual XP and run it on that......From the screen shot it's asking for the first disc, you need to go into the program and run the EWA net......Mine didn't ask for disc 1, it asked for 2/3/4/5....I don't have discs just the program so I installed a virtual drive (4 of)...When I changed to my new PC I pre-loaded 4 virtual drives and was expecting it to ask me for cd's which were on the drives, however it found them on it's own. Do you have installation instructions? I can post them in PDF................Full instructions.
File Type: pdf EWA-net EPC WIS Installation Instructions.pdf (1.63 MB, 3985 views)
SHAUNE55 is offline
post #20 of 25 (permalink) Old 03-08-2011, 10:57 AM
Quoted: 39 Post(s)
Complete installation instructions are included in the installation DVDs. The pdf from the previous message works mostly except that one probably looses datacards with fresh SW releases. Sometimes this approach also fails at the change from the first DVD to the next one.
I've tried to install EWA NET on a Vista computer and it was fine, I've also seen forum members succeeding with Windows7 but I always use XP.
EPC WIS&ASRA DAS Key Generator GDTm© General Mercedes-Benz 29 06-18-2015 01:21 PM
Help 2 install WIS/ASRA Star Diagnosis DVD manual Teutone General Mercedes-Benz 21 05-01-2011 02:02 PM
Help 2 install WIS/ASRA Star Diagnosis DVD manual Teutone W126 S,SE,SEC,SEL,SD,SDL Class 7 08-19-2010 01:41 PM
WIS / ASRA / DAS mb230s G-Class 12 06-23-2010 11:49 AM
WIS/ASRA plus EPC installed and running Teutone W126 S,SE,SEC,SEL,SD,SDL Class 8 07-17-2009 11:32 PM
