ac not cold - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 08-20-2006, 09:54 AM Thread Starter
Date registered: Jul 2006
Vehicle: 1999 c 280
ac not cold
Was wondering what might be wrong if the ac is blowing great but is not cold at all? This just happened yesterday and was ice cold and now nothing....Might it just be freon that I need? As far as I know I've never had it checked or replaced. Help! It's way hot in Alabama!!!! Thanks
hschadt is offline
post #2 of 6 (permalink) Old 08-20-2006, 12:55 PM
Date registered: Mar 2006
when ac is not cold its usually due to the freon gas... but in this case, if it happened all of sudden, your gas might be leaking somewhere...
s430owna is offline
post #3 of 6 (permalink) Old 08-20-2006, 01:02 PM
battlecat714's Avatar
Date registered: Sep 2005
Send a message via AIM to battlecat714 Send a message via Yahoo to battlecat714
yea plus you can always recharge it yourself.
battlecat714 is offline
post #4 of 6 (permalink) Old 08-20-2006, 01:52 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 733 Post(s)
I'm not too sure hschadt, but if it suddenly went from ice cold to outdoor temperature, your system has certainly experienced a failure above and beyond a simple freon recharge. Is the compressor still functioning?
GeeS is offline
post #5 of 6 (permalink) Old 08-20-2006, 03:16 PM Thread Starter
Vehicle: 1999 c 280
ok...so it appears that the compressor is fine and in good working order. Since it is a closed sysytem, there is still plenty of freon and there were no leaks according to the diagnostics. It looks as though it may be an expansion valve inside the dash that is not working properly. They say it will be a simple repair but they have to go in through the dash which is time consuming so it will be costly (labor)....UGH!!!! Has anyone ever heard of this?
hschadt is offline
post #6 of 6 (permalink) Old 08-20-2006, 03:38 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 733 Post(s)
Sure, expansion valves can fail. Don't be too upset -- it could have been a lot worse.
GeeS is offline
    How cold is the A/C? neilbo75 C208/A208 CLK-Class 14 07-13-2006 11:41 AM
    It's cold. deathrattle Off-Topic 21 03-04-2006 07:45 PM
    93 190e AC is Cold, then blows hot, Heat blows hot, then cold hippiechick W201 190-Class 8 10-20-2005 11:35 AM
    AC not cold bktank W202 C-Class 4 06-23-2005 06:05 PM
    Too cold? howards G-Class 1 12-09-2002 03:10 PM
