Help! AC Clutch Engages only when Jumped to the Battery - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-16-2006, 10:56 AM Thread Starter
Date registered: Jul 2006
I've been trouble shooting my AC system for a few weeks now. I finally was able to figure out that the AC compressor & clutch were working, the system had gotten low on freon and shut itself off. So I was able to jump the compressor to fill the system with freon, which is now reading at about 40PSI. Now I am stumped. I'm at the point where the AC clutch engages only when it is jumped to the battery terminal, when I do this I have nice and cold AC. But the clutch doesn't engage when I put the AC on in the car or the defrost like it should. I've checked all the fuses and they appear to be fine. I've tried to disconnect the battery to reset the computer in case the computer still had an error reading low pressure. And still nothing. Any suggestions?
cjsurf1 is offline
post #2 of 3 (permalink) Old 08-16-2006, 12:33 PM
Kajtek1's Avatar
Quoted: 1166 Post(s)
40 psi in the system to start with is way to low.
The pressure suppose to be checked with the compressor running and the low side suppose to stay at least 35 psi.
I believe high side goes to about 240 psi, but check this with manufacturer site.
Kajtek1 is online now
post #3 of 3 (permalink) Old 08-16-2006, 12:43 PM Thread Starter
Thanks for the information. I did check the low pressure side and that is what was reading 40 psi. But I'm not sure if that was checked when the car was running. I will re-check that. Where can I locate the high pressure port?
At what point will the compressor disengage when the pressure gets too low in the AC system? When enough pressure is put back into the system will the compressor begin to engage as it is supposed to? Or do you have to reset the system somehow?
cjsurf1 is offline
    Driver window jumped track...how do i fix? doctorkaligari R170 SLK-Class 7 07-29-2005 08:39 AM
    Transfer case diff lock engages on its own mortinson G-Class 3 10-23-2004 03:57 PM
    transmission engages with jerk ojef W124 E,CE,D,TD Class 5 04-30-2004 02:18 PM
    Guys who jumped the MB ship because of cost...How many were DIYs? 71Rcode W124 E,CE,D,TD Class 15 03-04-2004 07:58 PM
    G 500 - Just jumped on the 2002 G500 list Scott Taylor G-Class 0 09-12-2001 08:33 PM
