Mercedes Suspension - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 08-04-2006, 09:45 AM Thread Starter
Date registered: Jul 2006
Vehicle: 98 MB E320
Mercedes Suspension
Before I got my car (1998 E320) It had been sitting for 4 years in a garage. I had to replace all the fluids in the engine etc. to get it running safely.
But, I was told that I would probably have to get the suspension "done." Whenever I go over a speed bump or something, the suspension makes this noise that is really hard to explain. Like a little squeeky baby noise. I know for a fact that this was cost by the car sitting in one place so long.
Anyway, I wanted to know what I needed to get done to fix this and how much it would cost. Also, I wanted to know about the "spacers" that i can use to lower it .5 inches? Can I put the spacers in myself? Do they just pull out?
I would really appreicate the help, thanks
di_nate is offline
post #2 of 8 (permalink) Old 08-04-2006, 12:10 PM
mercedesman91's Avatar
Vehicle: 91 420 SEL
sounds to me like ball joints, i knwo for my moms 95 they were about 300 a pop, + labor....
Erik J. L.
91 420 SEL w/a 5.6 V8
89 300 TE Wagon
99 E 320
previous
95 C 280
93 190 E 2.3
95 E 320
mercedesman91 is offline
post #3 of 8 (permalink) Old 08-04-2006, 12:20 PM Thread Starter
Vehicle: 98 MB E320
300 a pop? as in 300 each?? -.- Also did your moms car sit for a long time?
di_nate is offline
post #4 of 8 (permalink) Old 08-04-2006, 12:37 PM
The Workshop MB's Avatar
Date registered: Apr 2006
Vehicle: 1988 300 TE. 2001 ML 55AMG The Shop is Open!!!
Suspension spacers
Where are you located, maybe I can help. Had a client who's 1997 E 320 was lowered (really low). Had to replace all shocks, springs and spring pads (spacers). If you like, you can reply with exactly what you need done.
I run a mobile service in the Bay area, call me if you like: 800 992 3694.
Happy Benzing!
The Workshop MB is offline
post #5 of 8 (permalink) Old 08-05-2006, 02:46 AM Thread Starter
Vehicle: 98 MB E320
Happy Benzing!
But I barely want to lower it, like .5 inches just with spacers or something. I heard I can do this myself?
di_nate is offline
post #6 of 8 (permalink) Old 08-05-2006, 07:36 AM
shandy's Avatar
Date registered: Feb 2006
Vehicle: 1995 C220 elegance auto.
Your squeaking noise may be the anti-roll (sway) bar rubber bushes squeaking, spray some silicon lubricant around the point where the bar passes through the bushes and it may stop them squeaking.
Regarding your suspension height the spacers come in different thicknesses as shown #11 on this diagram,http://www.detali.ru/cat/oem_mb2.asp...SGR=052&SGN=01. ,but you will need the correct internal spring compressor to do the job safely.
Geo.
shandy is offline
post #7 of 8 (permalink) Old 08-05-2006, 01:22 PM
Suspension
The correct spring tool is right. Aftermarket, around 600, MBZ original, about 900. this can be done for you, where are you? http://www.theworkshopmb.com/Coverage-Area.htm
Happy Benzing!
post #8 of 8 (permalink) Old 07-16-2007, 09:22 AM
"1995 E320 salvaged" Is it possible for someone to have installed lowering springs and not replaced the shocks? My rear shock absorbers appear to be too long, as at least 6 inches comes through the top mounting. Not sure what to do?
cjwolfcpa is offline
    Can you without problems change the V-class air suspension to spring suspension? kimberly V-Class 6 03-22-2017 06:10 PM
    Mercedes V280 Air suspension problem Dominic1968 General Mercedes-Benz 0 07-12-2006 10:57 PM
    mercedes v230 rear suspension NOISE MAEGANJADE The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 10-29-2005 01:20 PM
    Mercedes 560 SEL rear suspension problem SKSTravel W126 S,SE,SEC,SEL,SD,SDL Class 14 10-02-2004 12:27 PM
    1981 Mercedes Benz 380SEL Hydropneumatic Suspension dpaterso W126 S,SE,SEC,SEL,SD,SDL Class 5 03-31-2004 04:18 PM
