Transmission stays in low gear too long.. - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 08-06-2006, 10:00 AM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Quoted: 2 Post(s)
"Delayed shifting..."
Here's the straight poop, right out of my Owner's Manual (page 202): With transmission in gear range "D", "4" or "3", upshifting from 1st to 2nd to 3rd gear is delayed depending on vehicle speed and engine temperature. This allows the catalytic converter to heat up more quickly to operating temperatures.
During the brief warm-up period this delayed upshift and increased engine noise might be perceived as a malfunction. However, neither the engine nor transmission are negatively affected by this mode of operation.
The delayed upshift is effective w/ vehicle speeds below 31 mph at partial throttle and engine temperatures below 95 degrees F.
Don't believe everything you think
Jayhawk is offline
    long post! pre-filter stays almost empty,must take long trip tomorrow! vtharpe W123 E,CE,D,CD,TD,TE Class 8 05-22-2006 09:13 AM
    transmission thump/thud in low gear mikeyCLK C208/A208 CLK-Class 7 02-01-2004 03:20 AM
    How often do you use LOW gear? mwillems W163 M-Class 16 01-20-2004 10:39 AM
    Low Gear Not Engaging!!! Help!!! BETO Audio & Telematics Forum 0 01-28-2003 12:07 AM
    Update on 320 MT6 losing 2nd gear... dealer says that the transmission fluid was low... Jack R170 SLK-Class 2 08-15-2002 02:34 PM
