S500 1995 overheating problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-28-2006, 01:38 PM Thread Starter
Date registered: Jul 2006
Question S500 1995 overheating problem
Until recently, my '95 S500 always ran at an engine temperature of about 90. Now it will get up to 100 under normal driving conditions and goes up well over 100 on a hot day or going up a hill at slow speeds. My mechanic has replaced the thermostat, the radiator, the coolant, the water pump and repaired the electrical wiring to the fans. And the problem persists. Has anyone found another way to correct this problem? Would greatly appreciate your help before I have to rent a car to go to my niece's wedding in very hot Sonora California. Many thanks.
vtormey is offline
post #2 of 3 (permalink) Old 07-29-2006, 10:31 PM
The Workshop MB's Avatar
Date registered: Apr 2006
Vehicle: 1988 300 TE. 2001 ML 55AMG The Shop is Open!!!
running hot
sounds like you have replaced everything, but:
When your gauge reads 100, what is the acutal tempature of your cooling system?
Is the sending unit reading correctly?
Is your cooling fan operational?
Start the car, hold it at high idle (in park) until you hear a seemingly large roar sound (that is your cooling fan coming on).
Does this happen?
If all else if failing, you could have timing chain problem. possibly stretched, causing an unwanted advance or retard of the timing.
happy motoring!!
The Workshop MB is offline
post #3 of 3 (permalink) Old 07-30-2006, 11:11 AM Thread Starter
thank you for the reply. The timing chain is a new idea. I'll get this checked out. Thanks again.
vtormey is offline
    1995 S500 Transmission Problem krk230 W140 S-Class 0 03-05-2006 03:32 PM
    overheating problem BenzNoob W210 E-Class 7 01-12-2006 02:20 PM
    1995 S500 - Problem - Need Help krk230 W140 S-Class 4 07-17-2005 10:01 PM
    MY S500 IS OVERHEATING HMCGARY W140 S-Class 3 06-24-2004 01:42 PM
    1995 s500 0-60 and 1/4 mile ? m45 vs s500? who would win? s0vietbenz W140 S-Class 5 02-22-2004 12:27 AM
