Can someone help me with this? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 07-26-2006, 05:54 AM Thread Starter
Date registered: Jul 2006
Vehicle: Mercedez Benz ML 320
Send a message via AIM to pao89
Wink Can someone help me with this?
Hello everyone! I have a 1999 MB ML 320. Since last week I have been having problems starting the engine it has happened 3 times in a week). It looks like there is power because everything comoes on, I turn the key to start the car and It makes a noise like is going to start but it never does. If I try again in 10 or 15 minutes it will start with no problem. It drives fine, there are no other abnormalities just the starting the engine issue. Can someone tell me about it before I make any uneccesary expense? Sorry, I will admit it now yes I AM A WOMAN!!!! I'm supposed to not know much about cars so guys if you want to once again prove your point, tell a woman what to do!
pao89 is offline
post #2 of 10 (permalink) Old 07-26-2006, 06:50 AM
lnguyenh's Avatar
Date registered: Jan 2004
Vehicle: SL500, CL55, E350, E320
Quoted: 4 Post(s)
Do you have (or have access to) a voltage meter? You can use that to check the battery and the alternator.
lnguyenh is offline
post #3 of 10 (permalink) Old 07-26-2006, 11:12 AM
majorkahuna's Avatar
Date registered: Jun 2005
Vehicle: SL320/ML320
Does the problem occur with a cold or warm engine?
majorkahuna is offline
post #4 of 10 (permalink) Old 07-26-2006, 01:55 PM
asianml's Avatar
Date registered: Sep 2005
Don't forget to post in the W163 forum!
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
post #5 of 10 (permalink) Old 07-26-2006, 08:50 PM
Date registered: Feb 2006
Vehicle: 1979, 450 SL 1983, 500SL
Quoted: 2 Post(s)
Cool ME? Tell A woman what to do? HAHAHAHAHA
A woman is like driving on ice.
Sometimes you may influence her direction, but mostly you are just along for the ride.
noeljb is offline
post #6 of 10 (permalink) Old 07-26-2006, 11:15 PM
Diesel Benz's Avatar
Quoted: 37 Post(s)
Can you also describe the "noise" more accurately, is it just a "click" or is it like your starter motor was screaming (gears "slipping").
What is your mileage? If it starts "later", looks like the battery is not dead but instead a problem in your starter motor (specifically if it "tries", otherwise could be an immobiliser problem).
Diesel Benz is offline
post #7 of 10 (permalink) Old 07-27-2006, 07:11 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
With an electrical problem, typically it is either the battery, alternator or starter. The starter will make a click, click, click sound. Check your voltage before you start the car. It should be right around 12V. Start the car. Check the voltage again. I am not sure the exact voltage it should read. Typically it will be about 13-14.5V. I am sure someone can tell you the exact range. My range is pretty general. It could be your battery. If the voltage is low, it may charge up after a few hours and the car will start again. If it is the battery, just call the mercedes roadside assistance. The battery is a dealer only item and there is no installation charge. It could also be the battery in your key. I would start there. Get a new battery from Radioshack. What you are describing is exactly what happened to my wife in her ML320. She got in after work and it was dead. It started up the the next day. She drove to work. It died again that night. Turned out to be the battery. After 7 years it was done.
Mike
Michael Pillay is offline
post #8 of 10 (permalink) Old 07-27-2006, 08:12 PM
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
my advice - find a guy look at your car.
Kirill
Kirill is offline
post #9 of 10 (permalink) Old 07-28-2006, 12:35 AM
Ml320
May I also include my dilema w/ regards to the ML320, would highly appreciate any advise, comments and expertise.
First of all am a new member to this forum,
recently my predicament started w/ my ML 320 losing power from the accelerator
and brought it to a local service shop. According to them have to replace the accelerator acctuator and yet no improvements, next diagnose was the replacement of a certain computer module identified as Mercedes part no.A030 545 58 32 or Bosch part no. 261 206 968.
Now before I purchase this part is it going to make any improvements. My original suspicion was the fuel supply system. Because have been surfing in the net and read that a lot of ML320 owners experienced bad fuel pumps, can someone share some light to this?
Chideng is offline
post #10 of 10 (permalink) Old 07-28-2006, 06:11 AM
Quoted: 86 Post(s)
Try searching the w163 forum or posting your question there.
Mike
