1988 190D 2.5 Timing - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-25-2006, 08:02 PM Thread Starter
Date registered: Jul 2006
I got my brain thumping over this one. I did a head gasket on a 190d and i was informed by the dealer that if the cam sprocket was zipped tied to the chain and the rails were left in place the timing could not jump. Then after reasembly and the relization that the timing did jump the dealer kindly informed me that the timing could jump. From what I can tell the cam and crank are lined up but the fuel timing isn't. I did not remove the fuel pump but i was informed it would jump as a loaded cam would. I looked up in michelles about timing and it says you need a injection indicator that informs you when the number 1 is injecting and you need to have it inject 24 degrees before top dead center. That is just mind blowing to ponder how to set up. I tolk off the valve cover and the cover over the fuel spocket and noticed a mark on the chain. Is there any timing marks that will help me set up this timing? The why michelles says to change the chain is to cut the old chain holk a new chain in and turn it around until the old chain is out. It doesn't say if the chain jumped. Anyone that would help would be a god to me thank you.
whited is offline
post #2 of 2 (permalink) Old 07-25-2006, 08:03 PM Thread Starter
Well i am guessing the timing jumped it is knocking real bad and michelles says that is a fuel timing problem
whited is offline
    Timing Chain or Timing Belt on 230 Kompressor ? Bal C208/A208 CLK-Class 0 11-21-2005 01:08 PM
    1984 190D 2.2 Timing Chain Cover daveday W201 190-Class 0 03-18-2005 02:58 PM
    checked timing and timing advance mike_1972 Vintage Mercedes-Benz 0 06-28-2004 11:30 AM
    Timing chain replacement/timing issue 1990 420SEL supersport6 W126 S,SE,SEC,SEL,SD,SDL Class 1 12-09-2003 02:03 PM
    1988 2.3 Timing Chain or Starter? Guest (MBNZ) W201 190-Class 4 03-25-2002 04:07 PM
