Big problem..Where is my fuel pump relay??? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-19-2006, 01:17 AM Thread Starter
Date registered: Jun 2006
Vehicle: 1984 190E 2.3
First off this is a 1984 190E 2.3L...
I bought this car about a month ago and it worked just fine untill I had some problems with the fuel pump. It would occasionally die but I was usually able to start it back up.
Then it died completely a few weeks after that after working flawlessly for a few hundred miles. So I looked under the car and the pump was leaking fuel. I decided to replace it.
I hooked everything up, and turned the key. It would fire but not start.
When I turn the key it wont make any noise from the fuel pump. You know, the "bzzzzzzz" noise.
So I thought it might be the fuel pump relay so I go out to check and I can't find it! The book says it should be right by the main fuse box, right next to the relay you see in the picture. I circled the place where it should be in RED.
I'm really dumbfoudned about this because I can't even find the relay and I have no idea what the problem could be. All the fuses check out fine, but then again is there even a fuel pump fuse?
Anyway, here are some pics of my engine bay, around the fuses. I also included a pic of the manual where it says the relay should be.
Any help would be greatly appreciated. Please help! Thanks.
Dracus is offline
    1993 300E 3.2 problem starting, fuel pump relay again? FmrLCpl W124 E,CE,D,TD Class 14 12-06-2014 12:09 PM
    Fuel Pump Relay H1284 R/C107 SL/SLC Class 5 06-14-2004 08:11 AM
    fuel pump relay jaycarlos W124 E,CE,D,TD Class 1 03-14-2004 09:49 PM
    Fuel Pump Relay Problem nkowi W123 E,CE,D,CD,TD,TE Class 2 07-20-2003 08:56 AM
    190E Fuel Pump Relay/Electrical Problem ToddR W201 190-Class 1 05-29-2003 09:40 AM
