Wiring Harness Insulation Disingegrating on E320 - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-07-2006, 12:19 PM Thread Starter
Date registered: Jul 2006
Vehicle: 1995 E320
Send a message via Skype™ to haimur@shaw.ca
I was most disappointed yesterday when my MB dealer informed me that my 1995 E320 required a new wiring harness.
This machine lives inland, is not subject to salt corrosion, and is kept clean and stored in a garage. No obvious reason for it to be falling apart.
This is my fourth MB and the others NEVER had wiring that broke down by itself.
Did they use inferior wiring on this model, or is it just dumb bad luck on my part?
haimur
haimur@shaw.ca is offline
post #2 of 6 (permalink) Old 07-07-2006, 01:19 PM
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 2000 Designo SLK-05 C230WK-05 E320CDi-2010 GLK 350
Check for rodents. They like the taste of the newer insulation and this is a lot more common a problem than you would think. Bait some traps where you park your car and see what happens.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline
post #3 of 6 (permalink) Old 07-07-2006, 03:02 PM
battlecat714's Avatar
Date registered: Sep 2005
Send a message via AIM to battlecat714 Send a message via Yahoo to battlecat714
welcome to the club, never heard of a good harness on a e320 before and guess I won't. This is where MBZ f*cked up...Get it replaced and move on.
battlecat714 is offline
post #4 of 6 (permalink) Old 07-07-2006, 04:25 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Harness was made to be biodegradeable and does it too soon. Volvo had same problem.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #5 of 6 (permalink) Old 07-07-2006, 07:29 PM
That was and is a common problem not only with the E-class cars of that period but the S-class as well. Heat and viberation are the culprits. The insulation will harden and crack exposing the bare wires. The wires will then start to contact each other and cause missfires,check engine lamps,and various other problems. You have no choice but to replace the harness. When you have it replaced ask to see the old one. Take one of the wires and bend it,you will see the insulation crack not bend.
benztoofar is offline
post #6 of 6 (permalink) Old 07-08-2006, 09:54 AM
majorkahuna's Avatar
Date registered: Jun 2005
Vehicle: SL320/ML320
All 93-95 MB have the wiring harness problem. There was a requirement they be biodegradable. Well they certainly are. Why MB did not cover this under a recall is a mystery.
majorkahuna is offline
