1984 SD 380 Fuel Injection Problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-23-2006, 09:11 AM Thread Starter
Date registered: Jun 2006
I am running into problem with my 1984 SD 380. I replaced fuel pump. Every once in a while it stops on the road. It has been doing like that for last few days.
If I open the air-filter box, and push the plate a lilttle down. It starts working.
Does anyone know what needs to be done to fix it?
richard_john_81 is offline
post #2 of 2 (permalink) Old 06-23-2006, 10:36 AM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 16 Post(s)
Okay,I'm guessing this is a gasser ( SD ?? ) . Sounds like you need to either adjust the minimum air , adjust the potentiometer , or check the rest height of the airflow sensor plate. Worst case scenario is your control pressure is too high limiting the amount of fuel able to be delivered.
Nutz 4 Benz is offline
