S500 Limp Home - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-15-2006, 06:01 AM Thread Starter
Date registered: Jun 2006
Vehicle: 1985 and 1983 Mercedes 300D
S500 Limp Home
I just bought a 2000 S500 that was shifting perfect. Now all of a sudden it is stuck in limp home mode. I think that the kick dowm switch behind the gas petal has gone bad but I can't be sure. What else could it be........
ddfletch is offline
post #2 of 3 (permalink) Old 06-15-2006, 07:49 AM
Kajtek1's Avatar
Quoted: 1289 Post(s)
Scan the car for error codes.
Autozone is offering free rental of advanced scanners.
Kajtek1 is offline
post #3 of 3 (permalink) Old 06-15-2006, 10:11 PM
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Vehicle: 2000 E55 AMG
The current mileage on your vehicle would be a factor here. Nonetheless, it may be your transmission shift module. The seal within the transmission shifter box has been known to disintegrate causing transmission fluid to leak into the unit. Another possibility is the lack of transmission fluid or a need to flush the transmission fluid. You may also have a loose wire which is not communicating with your ECU. In either case, a visit to the MB dealer or a reputable transmission shop may be in order. Good luck.
ruBENZ_00E55 is offline
