Garage remote and built in remote does - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 06-07-2006, 06:04 PM Thread Starter
sstomcat's Avatar
Date registered: Jun 2006
Vehicle: ML-55 - 2000,
Quoted: 20 Post(s)
not work....have followd the owners manual and it does not work....when I poin the remote and press the button on the built in remote the light flashes fast but still does not work....any experiences?
thx
sstomcat is offline
post #2 of 22 (permalink) Old 06-07-2006, 06:17 PM
Date registered: Apr 2006
Vehicle: 2005 SL500, 2007 GL450
Same with both of my vehicles. I have followed the instructions (for my rolling code garage door openers).
PH1958
(Previous) 1997 Smoke Silver S320
(Previous) 2006 Brilliant Silver S430 4-Matic
2002 Champagne Lexus RX300
2007 Brilliant Silver GL450 4-Matic
2005 Brilliant Silver SL500
2010 Sea Mica Lexus LS460L AWD
2012 Crimson Red BMW Z4 iDrive28
ph1958 is offline
post #3 of 22 (permalink) Old 06-07-2006, 06:21 PM
mine too
Mine doesn't work either. I followed the instruction and tried to get it set up probably 6 times to no avail. I was bummed because that's a neat little feature. Oh well.
OrangeTJ is offline
post #4 of 22 (permalink) Old 06-07-2006, 07:45 PM
raymond-'s Avatar
Date registered: Jan 2004
Vehicle: 99 E320
Quoted: 131 Post(s)
99 E320 garage door opener in the inside rear view mirror works great...with my
rolling code Genie
raymond-
47º34'N 122º18'W
raymond- is offline
post #5 of 22 (permalink) Old 06-07-2006, 07:50 PM
Date registered: Nov 2005
sstomcat
with the ML and new garage doors you need to follow the same instructions but you need to push the button by the light on the garage door opener. I should be a red button. It has to do with rolling code stuff. I had to do that with both the ML55 and the E55
Good luck
d
Mad TKD is offline
post #6 of 22 (permalink) Old 06-07-2006, 09:00 PM
Vehicle: 12E350, 12ML350, 08C350
I can remember (a few years back) when I got my wife 00E320. I was trying with the instructions in the manual, it does not work. My garage opener has rolling code (brand is Lift-master, but made by Genie), if you have the same brand (or similar), try this : get a step ladder, look at the side of the opener, there is a door size 3 by 2 1/2 inches), pry open the door (use the flat head screwdriver), inside the is a RED square button), hit that button the light on the opener will flash, get the cars key into the ignition, turn on position 2, hit the mirror's button (what ever you prefer to program it) ,you have only 1 minute to do this. The light on the button you hit will learn the code from the garage opener, when the light on the garage opener (Lisf-master) stop flashing, it means that it added another garage opener to it (instructions manual DO NOT say this), bingo, you are set . Anyone still can not program, call MB for assistance (I called them ,but they told me to take the car to the dealer), I did some research to get this rolling code to accept to my 2 MB's car, beside my 2 regular Key Pads (whick no longer used).Good luck. PM me if anyone need help.
00CLK208 is offline
post #7 of 22 (permalink) Old 06-08-2006, 07:07 AM
Quoted: 30 Post(s)
I have a Lift Master too and just programmed the remote opener on the mirror of my '99. It woks now, but apparently the code sequence changed and now the hand held opener that came with the door doesn't work. I guess I need to do both of them at the same time.
BTW, it gets program just like the post above indicates.
Len
sokoloff is offline
post #8 of 22 (permalink) Old 06-08-2006, 07:20 AM
D2k
D2k's Avatar
Date registered: May 2005
Vehicle: 05 A6 3.2Q, 07 A4 2.0T S-Line
You may have some old codes stored in your Homelink too. If so, you have to reset the unit and clear all the codes before you can store new ones.
D2k is offline
post #9 of 22 (permalink) Old 06-08-2006, 09:23 AM
Premium Member
roncor's Avatar
Date registered: Jan 2005
Vehicle: '91 420 SEL, '80 240D, '87 560 SL, '93 190E Sportline, '70 300 SEL 6.3
Quoted: 40 Post(s)
Premium Member
remote - homelink
Guys, please, go to the homelink web site and follow directions. It is very simple....
http://www.homelink.com/training/train.taf
roncor is offline
post #10 of 22 (permalink) Old 06-08-2006, 01:17 PM
Bill of Ojai's Avatar
Opener
After having successfully programed my opener in a C280, I could'nt figure ou twhy it would not work in my C230. Found out I had to put the ignition key all the way on, not he first detent.
Bill of Ojai is offline
