huge drop in fuel economy 1981 300D - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-01-2006, 11:37 AM Thread Starter
Date registered: Jun 2006
Vehicle: 1981 123 300D
Question huge drop in fuel economy 1981 300D
I am brand new to this forum. Wish I had found this forum long ago!!!
I have a 1981 123 300D with 355,000 miles. Highway fuel economy had been at 28 mpg and in town at about 24 mpg for the last 10 years. Fuel economy has been dropping steadily over the last two years and is now at about 20 mpg highway and in-town.
Any thoughts on the problem and solution.
Air filter is new, fuel filters have about 6,000 miles on them. Doesn't seem to be a loss of power on the road. The glow plug light operates properly. The only noticeable new engine quirk is that the engine runs very rough when cold starting in the morning but smooths out after about 15 seconds. And over the past year I have experienced that the engine won't always shut off from the ignition. I have to pop the hood and shut if down manually.
Thanks in advance
paddle is offline
post #2 of 5 (permalink) Old 06-01-2006, 12:39 PM
smallfence's Avatar
Date registered: Jan 2006
Vehicle: 1981 240D
it might also help to post your question in the W123 forum...other than that I'm not sure what to tell you right now!
20,000mi on biodiesel and counting!
smallfence is offline
post #3 of 5 (permalink) Old 06-01-2006, 06:15 PM
Kajtek1's Avatar
Quoted: 1289 Post(s)
I did diesel purge on my old 300d in the past and it helped. When was the time you changed injector, or injector tips?
They have kits on ebay.
Kajtek1 is online now
post #4 of 5 (permalink) Old 06-01-2006, 08:10 PM
smallfence's Avatar
Vehicle: 1981 240D
good suggustion. maybe the car is also due for a valve adjustment?
the shut off problem is common...usually related to a leaky vacuum line. See here http://www.benzworld.org/forums/w123...st-2-days.html
that should get you started but it doesn't sound that bad
post #5 of 5 (permalink) Old 06-02-2006, 05:15 AM Thread Starter
Thankyou. the vacuum pump has been replaced and the brakes work fine. the shut off valve may very well be the culprit unless there is a leaky line.
The injector tips have not been replaced. The glow plugs were replaced and converted to pencil type units. The precumbustion chambers may also need cleaning.
paddle is offline
