1999 E320 Climate control light repalcement - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-30-2006, 01:49 PM Thread Starter
Date registered: Apr 2006
Hello,
Wondering if there is any documentation for climate control unit light bulb repacment. I have purchased the tool to pull the unit but not sure what the process is to complete the objective.
Any help would be greatly appreciated.
Greg
ggold is offline
post #2 of 5 (permalink) Old 04-30-2006, 02:24 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
My 01 is probably identical, I had the control out to remove a "no mar" mounting bracket for my cell phone.
Put in the keys they will retract the latces and it will silde out there are two connectors that pivot after releasing the catch. They will release the plugs. I t looks like the bulb is in the bottom in a
Peter Guenther is offline
post #3 of 5 (permalink) Old 04-30-2006, 03:04 PM Thread Starter
Hi,..thanks for the quick response. Can I perfom this with out any disconnection of electrical,..ie battery??
ggold is offline
post #4 of 5 (permalink) Old 04-30-2006, 03:24 PM
To install( and remove) the bracket, I needed to remove the panel. The instructions, just said unplug the control. I have done it, the radio control they said to leave connected since you would have to recode it. As I said put a wash cloth or towel between the control and panel to avoid scratching. There was ample cable length to slide out and turn over. I made a mental note "so there is" the bulb. It appears as there is a socket, and would get the bulb ahead of time, its probably one of the "miniature things"
post #5 of 5 (permalink) Old 05-03-2006, 03:59 AM Thread Starter
Hi again,
GREAT thx. So I assume I can just pull the Climate control unit out with no worries about the elecrical so long as the car is not running
ggold is offline
