Braking causes dashlights to illuminate in W140 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-30-2006, 12:40 PM Thread Starter
Date registered: Apr 2006
Vehicle: 2005 SL500, 2007 GL450
In my 1997 S320, depressing the brake pedal causes the dashlights and the light-bulb-out light to illuminate. I have 140,000 miles on the vehicle. This strange situation just began today. Any thoughts on the cause? Possibly a worn switch at the brake pedal?
PH1958
(Previous) 1997 Smoke Silver S320
(Previous) 2006 Brilliant Silver S430 4-Matic
2002 Champagne Lexus RX300
2007 Brilliant Silver GL450 4-Matic
2005 Brilliant Silver SL500
2010 Sea Mica Lexus LS460L AWD
2012 Crimson Red BMW Z4 iDrive28
ph1958 is offline
post #2 of 4 (permalink) Old 04-30-2006, 08:01 PM
Date registered: Dec 2004
Vehicle: 03' SL500
Sounds like a possible corrosion in a lamp socket (rear brake light) causing a jumping of the circuit from the brake light portion into the parking light circuit back up into the dash lights. Your parking lights are probably coming on dimly at the same time. Take a look.
Glenn B
glennbaz is offline
post #3 of 4 (permalink) Old 05-01-2006, 02:32 AM Thread Starter
Thanks for the suggestion. I will investigate that possibility.
PH1958
ph1958 is offline
post #4 of 4 (permalink) Old 05-01-2006, 03:56 PM Thread Starter
It turns out that I grabbed the wrong bulbs (from my kit). Once I installed the correct bulb, the problem was solved.
Thanks!
PH1958
ph1958 is offline
