Merc A170 CDI headlamp bulb replacement? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-02-2006, 10:46 AM Thread Starter
Date registered: Apr 2006
Hi,
Can anyone tell me how to remove the headlamp casing so I can change the dipped bulb? I cant get fingers behind and it looks like the whole unit can come out and I have removed the two placment bolts for the case?
Any help appreciated.
Mike
landprojects is offline
post #2 of 2 (permalink) Old 06-01-2007, 11:23 AM
Date registered: Apr 2007
On the passenger side you will have to lift out the water sprayer to one side. the bulb sits in a type of sleeve that you press down to remove the fitting with the bulb attached. When new bulb is fiixed in place you have to move the slide back up which is sitting on the side. Hard to explain, but easy to do. Have a go.
dermo is offline
