Pls Help!!! Instrument Cluster Issues W202..Have Searched all Post here none answers my questions! - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 06-10-2010, 09:53 AM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
I might suggest you spray the electrical stuff with CRC Electrical Connection Cleaner. It doesn't leave a residue like WD-40, and you don't run the risk of shorting through the petrochemicals in WD-40.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #12 of 14 (permalink) Old 03-14-2011, 03:21 PM
Date registered: Mar 2011
W202 Instrument Cluster Fault-why replacing it is simple
Same problem with my W202 instrument cluster. LED mileage display failed, fuel guage dead, rev counter stuck at zero, revs also at zero. Only temperature guage works. rev counter needle flickering ever so slightly and barely visible. Indicators, headlight flashers and background lighting all still working.
no need to remove steering wheel remove the side tweeter grill cover remove the air vent, push the cluster out by putting hand in the back of the cluster and pushing forward towards you. disconnect the multi pin connecter horizontal one first by sliding the cluster half way out towards the door (RHD Vehicle). push back to as if re-fitting it, turn steering wheel slightly to the left or Nearside if you prefer, and now push this side of the cluster towards the nearside which will expose the vertical multi pin connecter, now disconnect this. after having removed both the multi pin connecters carry on sliding the cluster towards the nearside and it will slide out at a slight downward facing angle.
fit new cluster but fit the horizontal connecter as soon as you can in the process and then the vertical when past center point. very easy proceedure takes about 20 minutes. DO NOT PUT IGNITION ON UNLESS YOU really have to ie releasing steering lock as this will mean having to live with an air bag light staying on after ignition for a bit or get the light re-set.
If you take the cluster out again I wonder if the air bag light will re-set itself? may try that next time if anyone here really gets stuck with this cluster problem.
HAD TO WRITE up as I didnt get the answer very easily to this probelm anywhere on the merc forums.
The replacement cluster by the way has the mileage of the car it came off, so take the old cluster when having an MOT done, it will save a lot of embarrasment.
rustfree0 is offline
post #13 of 14 (permalink) Old 01-27-2013, 06:23 AM
Date registered: Oct 2012
Any luck!!!!!!!!!!!!!! I am having a same problem
mohamed qayum is offline
post #14 of 14 (permalink) Old 01-27-2013, 01:41 PM
Date registered: Dec 2012
Vehicle: 87 560SL, 71 280SL euro, 74 VW Ghia, 78 280Z Black Pearl, 78 280Z, 04 Corolla, 07 Odyssey, 94 Prizm
One thing I will recommend you guys. DO NOT TEAR APART YOUR INSTRUMENT CLUSTER!! If you do mess it up, it is not cheap. You can put one from another car, but I don't think it will work well. What I CAN suggest all of you who are having problems with your instrument cluster is to call an expert in MB clusters. There is a company in Palo Alto, California that specializes in just speedometers and instrument clusters. The company is called PALO ALTO SPEEDO. Their website is Palo Alto Speedometer: Repair, Restoration, and Sales of Automobile Gauges. They specialize in these instrument clusters and can repiar them. Give them a call and get a quote. I have used them in the past and I get excellent results and service. CHEERS!
OzzyQ80 is offline
