Oil pressure readout problem on the cluster - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-27-2006, 04:16 PM Thread Starter
Date registered: Mar 2006
When starting my 190E 2.6, (1989, in the morning, the oil pressure reads 3 bars. As the engine heats to operating temp, the dial indicates at max 1.bars. Is this dial operated by a vacuum hose or am I looking at a bigger fix? Any help? Thanks
dfmtpabay is offline
post #2 of 6 (permalink) Old 03-27-2006, 07:24 PM
Date registered: Jul 2004
RE: Oil pressure readout problem on the cluster
I never trust oem gauges, I would hookup a real one for a comparo. I've had many cars with poor oil pressure at idle when hot. All the way down to zero psi, but it never seems to affect anything.
Low oil pressure and driveline vibrations follow me from car to car, it's my personal jinx.
Chevota is offline
post #3 of 6 (permalink) Old 03-27-2006, 08:24 PM Thread Starter
Thanks, that's my thoughts. Do you know if the guage is controlled by a pressure/vacuum hose?
post #4 of 6 (permalink) Old 03-27-2006, 08:50 PM
Date registered: Jul 2005
Quoted: 1014 Post(s)
It is an electronic sensor.
Noodles is offline
post #5 of 6 (permalink) Old 03-28-2006, 08:26 PM Thread Starter
Thanks for the input. My problem is that according to the schematic of the oil pump, it doesn't use a typical "wankel" sort of pump. As such it would not necessarily fail as the engine got warmer.
The problem I have is that the oil pressure dial on the dash cluster goes to 0 after assuming engine operating temperature. I'm thinking that it is probably a sending unit or sensor. There shows a sensor in the oil filter assembly on the back of the engine.. Is this what sends the info to the dash cluster?
post #6 of 6 (permalink) Old 03-29-2006, 05:58 PM
Not sure on that 6 cylinder. Somebody must know.
Noodles is offline
