engine mounts - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-25-2006, 09:14 PM Thread Starter
99CLKcab's Avatar
Date registered: Mar 2006
Vehicle: 1965 Peel Trident, 1972 chevy vega
Send a message via AIM to 99CLKcab
engine mounts
Has anyone had their engine mounts changed? From what I hear, its pretty standard. How much shlud this cost. I saw the mounts online for $73, I have a 99 clk320. Any idea?
99CLKcab is offline
post #2 of 6 (permalink) Old 03-25-2006, 10:00 PM
Andrew2004az's Avatar
Date registered: Feb 2004
Vehicle: 02 ML 320
RE: engine mounts
Call up your dealer and ask how many hours it will take them in labor. Then times that by at least $100 an hour. I know for my ML they did both engine and transmission mounts and they had the car for 2 days. I will look and see if it says on my sheet how many hours of labor it took for the engine mounts since we have the same engine it should be similar.
Andrew2004az is offline
post #3 of 6 (permalink) Old 03-26-2006, 12:47 PM
Vehicle: 2004 clk 500
RE: engine mounts
engine mounts on a 320 clk should be about 2 hours labor
benztech81381 is offline
post #4 of 6 (permalink) Old 03-26-2006, 03:51 PM
murton's Avatar
Vehicle: 91 300CE, 00 SL500
RE: engine mounts
I've changed engine mounts on 3 Benz's over the past 5 years. It is a standard repair and won't take too long to do. I am not familiar with the CLK's situation, but I can tell you that there are real differences between the engine mounts on some models versus others so be careful what you buy. For example, the mounts on my 300D were less than $100 each and were simple rubber mounts. The ones on my 300CE were a combination of rubber and metal(with compression diaphrams, so they were about $300 each.)[xx(]
murton is offline
post #5 of 6 (permalink) Old 03-26-2006, 10:57 PM Thread Starter
99CLKcab's Avatar
RE: engine mounts
Thats the mount, this is what is says:
Engine Mount
Febi $95.00
Vehicle:
1999 Mercedes Benz CLK 320 Cabriolet
Fits Engine - Chassis:
112.940 — 208.465
99CLKcab is offline
post #6 of 6 (permalink) Old 03-27-2006, 09:51 AM
imon_2nd's Avatar
Vehicle: 1993 300CE Cabriolet
Quoted: 2 Post(s)
Send a message via Yahoo to imon_2nd
RE: engine mounts
[8D]
99CLK,
The indie MB mechanic I use quoted me $500 complete: parts, labor, and tax. That sounded high, so I'll wait until they are totally shot before having them replaced. He said they are still good enough to run with, for now, and the reason the motor vibrates more than normal at idle is, there is no more fluid inside the mounts.
Cheers!
Dave
imon_2nd is offline
