I Need Offset et help !!!!!!! - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-21-2006, 03:45 PM Thread Starter
Date registered: Mar 2006
I have a 2002 mercedes c240 .. the factory rims are 16 x 7 inch alloy wheels .. i brought 17 x 8 inch aftermarket amg monoblock style chrome rims .. the offset on the chrome rims is et 20 .. my steering wheel starts shaking when I hit 60 mph and above .. I've been told that the reason for this is the offset et number is incorrect .. I am sending the rims back to get rims with an offset et that will fix this problems .. any ideas on what offset et number I should get ?
PiTo3NyC is offline
post #2 of 4 (permalink) Old 03-21-2006, 04:39 PM
waybomb's Avatar
Date registered: Apr 2005
Vehicle: 2005 S55; 2003 ML350; 2002 C240; 1997 C280 Sport; 1991 300SL; 1986 190e 2.3 16V (2); 1968 W30 442
Quoted: 7 Post(s)
RE: I Need Offset et help !!!!!!!
Offset should not make them shake.
Are they hubcentric? Did you get them dynamically ballanced?
If the offset is wrong, the rims or the tires will rub on suspension or body parts, but that's about it.
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
1988 46' Cougar US1 with Triple blown 572s
Warming the Globe, 24 Cylinders at a Time
Point me to a 126 wagon in the States PLEASE!
waybomb is offline
post #3 of 4 (permalink) Old 03-21-2006, 10:40 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 937 Post(s)
You should be o.k. with Et 20. Sometimes you might just have a bad tire. Check the bolts? Even new rims can be defective. Were they new? If not, have them re-balanced. If the seller/tireshop made that offset remark, have it done somewhere else, and mount the best in front. Did you hit anything/pothole etc. Start with rotating the wheel(or wheels) with the rear and see if it still shakes. Otherwise you need to have a look at the suspension. For info on wheels/offset check out the net or the tirerack site on top. Good luck, Horst K
Teutone is offline
post #4 of 4 (permalink) Old 03-22-2006, 08:44 AM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Quoted: 2 Post(s)
You will get much more/better assistance if you post this in The Tire Rack part of the forum.
Jayhawk is offline
