ignition problems - Mercedes-Benz Forum
post #1 of 27 (permalink) Old 03-12-2006, 05:03 PM Thread Starter
verdejor's Avatar
Date registered: Aug 2005
Vehicle: 1976 W116, 450SE --- 1981 W126, 380 SEL--- 1972 W108, 280SEL---1963 W111, 200S
ignition problems
OK. 5 & 7 have no spark at all.
I grounded them and no spark.
Car basically running rough. ignition coil is new along with many other parts... exchanged wires from other working cylinder but same...
could it be the ignition control unit?
how can I diagnose?
It's not all that, But it's mine.
http://www.cardomain.com/id/verdejor
verdejor is offline
post #2 of 27 (permalink) Old 03-13-2006, 10:56 PM
nenad16's Avatar
RE: ignition problems
could be a cracked distributor cap.
btw, Im in honolulu, too.
nenad
nenad16 is offline
post #3 of 27 (permalink) Old 03-14-2006, 10:34 AM Thread Starter
verdejor's Avatar
Cool, what part you live in?
I live on base @ Hickam AFB.
you can catch me on a saturday night @ Che pasta on Alakea & Bishop. I'm a Latin music percussionist on my time when not under a car...
I just replaced cap & rotor on the car..
verdejor is offline
post #4 of 27 (permalink) Old 03-14-2006, 11:07 AM
nenad16's Avatar
Cool, I'm in the salt lake area.
nenad
I'm not a bad christian, I'm a good atheist.
nenad16 is offline
post #5 of 27 (permalink) Old 03-14-2006, 07:01 PM Thread Starter
verdejor's Avatar
well, whenever you working on a car or anything.. I'm at your service. My casa is your casa...
post some pics, so I can check out u'r ride.
I'm working on mine right now of course, but the car looks nothing like the avatar... worse... it's primered looking like a hawaiian rainbow..
see my link on the Lowering car post I started...
verdejor is offline
post #6 of 27 (permalink) Old 03-14-2006, 08:24 PM
nenad16's Avatar
Thank you, I'll keep that in mind.
As for the ignition problem, can you explain what you changed and how it all started? if only two cylinders are not firing, the most likely cause is a cracked cap. but you say you replaced it, now did this problem start before or after you replaced it? are those two cylinders the only ones not firing, if every time you check spark and you get different cylinders not firing, this is most likely a bad distributor, as far I can remember, 380's dont have points, so you are most likely looking at the distributor contacts or a discharging condenser(its the plug with the green wire that connects the distributor with the control module). check those things out and let me know.
nenad
nenad16 is offline
post #7 of 27 (permalink) Old 03-14-2006, 08:29 PM
nenad16's Avatar
here a some pics of my rides:
this one I sold recently
my 420 is on craigslist:
http://honolulu.craigslist.org/car/139707924.html
nenad
nenad16 is offline
post #8 of 27 (permalink) Old 03-15-2006, 12:54 AM Thread Starter
verdejor's Avatar
nice ride dude.
thanks for the tip, I thought it could be the green condenser wire, but don't really know how to trouble shoot it.
I will buy new spark plug wires also.. I think "Buru"? don't know the name exactly...
I still have the "old" cap, but neither are cracked.
you are correct..no points in car.
I'll let you know what happens.. it'll take about a week since I have to order the condenser cable + install it. maybe buy the idle control unit and if I don't need it, return it?
it's the same cylinders not firing...
I bought the car with this problem, the guy didn't have money to fix it & had recently inherited it...
I knew the story + got the car checked for compression, etc.. all good the mechanic said it probably was the FUEL distributor, but I get gas to all injectors.. he also quoted me 4000min-5000max, of course... I ran away. LOL
I know it is an "electrical problem" everything else checks out okay to me. = this car is not equipped with a "computer/idle control unit"
b.t.w. : I like the avatar... LOL
verdejor is offline
post #9 of 27 (permalink) Old 03-15-2006, 01:12 AM
nenad16's Avatar
$4-5K? who did you take it to, german cars or mb specialists? either one of those are very expensive and mb specialists dont even know what they are doing. If you still have your car in the next few months, my shop will be up and running again, I'll gladly maintain your car.
My shop is Pera European Cars, we used to be on Waimanu st, right behind the bmw dealership. The building got sold by the owner, so we are looking for a new place right now.
nenad
nenad16 is offline
post #10 of 27 (permalink) Old 03-15-2006, 10:21 AM Thread Starter
verdejor's Avatar
thanks, I'll look it up, or gimme an address when you get it open.
I appreciate all the free tech info you passing on.
yeah, when he started talking, I was saying in my mind "this guy is just not making sense"
$90 an hour to replace a fuel distributor = 4-5k?
I dismantled/cleaned manifold, upper plenum, removed distributor checked for leaks and only took about 5hours = $360 + parts
he won't accept parts either...
I understand they might be going by what the book says but dang, help a brother out LOL.
verdejor is offline
