squeak in back right wheel - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-08-2006, 09:17 PM Thread Starter
Date registered: Mar 2006
There is a squeaky noise comming from our right rear wheel on our 500ML. We took the wheel off to examine the break pads, and found them normal looking. There is a break pad light which should come on, on our dash if the break pads are warn,and this is not coming on. We went to a break shop,and they told us that all our breakpads need replacing along with rotors for the sum of $1100.00 We are reluctant to let them do this as we really don't think there is anything wrong with our breaks. It has been suggested that maybe our parking break is causing this,and were told to push it on with force,and snap it off several times. We did this, but still hear the squeak. Does anyone have any ideas? Does anyone else have this problem?
frances is offline
post #2 of 3 (permalink) Old 03-09-2006, 02:42 AM
Vehicle: 1993 300SEL (Sold) 2001 530i (Sold) 2008 C250
Quoted: 7 Post(s)
RE: squeak in back right wheel
How loud? If you get a stone stuck between the disc and the metal shield behind it then it will make a hell of a nopise try reversing and then going forwards in the driveway a few times. If it is this then it will be very loud because of the stone grinding on the metal.
Good luck
NZ Benz is offline
post #3 of 3 (permalink) Old 03-09-2006, 09:05 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Good: brakes are worn
Bad: breaks are warn
Good: Going to a Mercedes mechanic
Bad: Going to a brake shop.
Kent Christensen
'07 GL320CDI
lkchris is offline
