2005 E-320 CDI defroster and operation - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-26-2006, 09:50 AM Thread Starter
Date registered: Feb 2006
Okay, I have the defroster turned on and it works but it puts out nothing but heat in any setting virtually heating the car up like a oven. The dealer says this is what the car does. I have two other vehicles non Mercedes that the temperature is adjustable so you can have the damn thing on without leaving the windows down from the heat. Is this the case? Thank you.
brewerd is offline
post #2 of 4 (permalink) Old 02-26-2006, 02:49 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
RE: 2005 E-320 CDI defroster and operation
Defroster should be full heat only.
flyboyike is offline
post #3 of 4 (permalink) Old 02-26-2006, 02:54 PM
vwbuge's Avatar
Vehicle: 1985 300SD
Not 100% sure on your car but on older MB the defrost is for defrost only. Meaning all heat all the time. There is also another button on older MB that has two arrows pointing north and south. This is for ADJUSTABLE heat that flows through the defrost, midvents and floor.
Take the few minutes and read your owners manual.
vwbuge is offline
post #4 of 4 (permalink) Old 02-26-2006, 08:21 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
If you're talking about the pushbutton front defrost control it's purpose is maximum/quickest defrost. It will ALWAYS be maximum heat.
You're supposed to turn off the button and then rely on normal heat--some directed to windshield--for "demisting." Only the latter is contolled by temperature selection.
If you survey a bunch of European cars you'll always see the result of regulations requiring an easily determined path for max defrost. It's always and obviously max heat.
Understand of course the difference between defrost and demist.
Kent Christensen
'07 GL320CDI
lkchris is offline
