Peeling chrome on rims bad?? or good? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-25-2006, 11:08 AM Thread Starter
Mark600RRBryant's Avatar
Date registered: Aug 2005
Vehicle: SLK 230 Sport
Ok say I buy some rims that have some chrome peeling inside the rim, what kind of problems could I expect? would it still hold air?
Mark600RRBryant is offline
post #2 of 7 (permalink) Old 02-25-2006, 11:21 AM
peter811's Avatar
Vehicle: 1984 300D
RE: Peeling chrome on rims bad?? or good?
Yes the wheels will still hold air. I have found that the brake dust in most European cars have a small amount of acid in them, which tends to eat away the finish on alot of rims. Or in the case of chrome plating it will cause the finish to bubble and peel.
peter811 is offline
post #3 of 7 (permalink) Old 02-25-2006, 11:23 AM
worst mod in BW history
ThrillKill's Avatar
Date registered: Apr 2005
Vehicle: ML CLK Iridescent Hyundai Accent lol,GoPed Freightshaker & Volvo semi's, c'mawn?
Quoted: 5 Post(s)
You could expect the chrome to continue peeling, chrome however has very little if anything to do with tire pressure. The real question would be, is the chrome peeling as a result of structural damage to the wheel or is it simply age, chemical reaction, etc. If there is no physical damage and the wheels are true, rechroming would cost roughly, $125-$200 per wheel. If they're high-end wheels and the price is good it's worth it, otherwise look elsewhere.
ThrillKill is offline
post #4 of 7 (permalink) Old 02-25-2006, 04:37 PM
mcbear's Avatar
Date registered: Apr 2004
Vehicle: E500Es
McBear,
Kentucky
Being smart is knowing the difference, in a sticky situation between a well delivered anecdote and a well delivered antidote - bear.
mcbear is offline
post #5 of 7 (permalink) Old 02-27-2006, 12:59 PM Thread Starter
Actually one is allowed per state, I went ahead a regulated this through the supreme court. [:)]
post #6 of 7 (permalink) Old 02-27-2006, 07:27 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Advice above conflist with fact Mercedes has specifically issued technical advice prohibiting fitting chrome-plated wheels, actually mentioning leakage problems.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #7 of 7 (permalink) Old 02-28-2006, 06:01 AM
Date registered: Feb 2006
I have a set of 14" chrome rims on my 83 300SD.
They are peeling badly. One of the tires leaks at the rim edge badly. Some of the other tires need air more often then you would expect. I feel that the chrome peeling is the cause. I am now in the process of replacing these wheels.
Spokes is offline
