Overheating S420 - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 06-25-2011, 02:54 PM
Date registered: Apr 2011
Vehicle: 1995 s420
I have seen both fans turning recently - the driver side is slightly slower. Anyone have a pic of the sensor that controls these? I can't seem to find it - I read that if you disconnect it the fans will run on high all the time.
188k s420 is offline
post #12 of 14 (permalink) Old 06-25-2011, 08:06 PM
Minnet's Avatar
Date registered: May 2005
Vehicle: 1991 300SEL W140, Brabus, W220 facelift
It might be the main fan drive (viscous coupling) or simply incorrect position of the fan shroud causing the fan not to obtain adequate speed.
I had that problem, and it gave exactly the symptoms as you describe.
In the beginning that was further assisted by one of the auxillary fans going wrong way. Anyway, the auxillary fans are controlled by the A/C thermostat - not the coolant thermostat - so you are on wrong track.
1987 190E 2,3
1987 Honda Accord 2,0
Minnet is offline
post #13 of 14 (permalink) Old 06-28-2011, 06:48 PM
Date registered: Jun 2011
Vehicle: 1993 W140 500SEL- 90K miles White/Palomino, 1985 W126 380SE- 170K miles Grey/Black
Seri,
Is your A/C blowing cold when this overheating occurs? If the system is at good efficiency, you should see about a 20 degree temperature difference between the ambient air and the center vents in the vehicle (using a thermometer) with the setting on MAX cold.
Be sure that your A/C condensor isn't restricted with debris in addition to checking your viscous clutch. If it is,you'll generally have less airflow and diminished engine radiator cooling as a result. Just an FYI...
asvmac is offline
post #14 of 14 (permalink) Old 06-29-2011, 12:47 AM
Minnet's Avatar
Just as I made a mistake... Seri's post is 5 years old
1987 190E 2,3
Minnet is offline
