ignition key will not turn - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 02-19-2006, 08:01 PM Thread Starter
Date registered: Feb 2006
I attempted to start my E320 and the key will not turn. It seems to be locked, but I have no idea how it got that way. Any ideas on releasing this feature.
Charlee is offline
post #2 of 11 (permalink) Old 02-19-2006, 08:05 PM
asianml's Avatar
Date registered: Sep 2005
RE: ignition key will not turn
This may sound stupid, but did you try turning the steering wheel a little?
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
post #3 of 11 (permalink) Old 02-19-2006, 09:07 PM Thread Starter
Thanks and yes I tried to move the steering wheel, but no luck. I checked the gear shift and everything seems to be in order, but the key won't budge.
Charlee is offline
post #4 of 11 (permalink) Old 02-20-2006, 01:14 AM
TheRazz's Avatar
Vehicle: 1984 280SEL AMG
Send a message via MSN to TheRazz Send a message via Yahoo to TheRazz
Is the key bent in any way, sometimes a slight bend in the key can change it enough to make it INOP. Also, if your tire is against a curb you have to REALY turn the wheel both ways while trying the key... If all else fails, try a locksmith, or a TRUSTED mechanic...
Good Luck
Rich
1984 280SEL AMG
1984 F250 Diesel
1992 F.O.R.D. Explorer
1997 F.O.R.D. Expadition
1972 F250 (57K origanal)
1980 Suzuki GS750ET
Razz
I reject your reality, and substitute it with my own (Mythbusters)
TheRazz is offline
post #5 of 11 (permalink) Old 02-20-2006, 01:28 AM
NordStern's Avatar
Date registered: Dec 2004
Vehicle: 300TE 4-Matic 300GD
Hi Charlee.
Is it stuck in the ignition?
If it is, try recharging the battery, or get someone with a start pack to help you. If you must, use jump cables.
Regards
Geir
NordStern is offline
post #6 of 11 (permalink) Old 02-20-2006, 03:16 AM
~BANNED~
deathrattle's Avatar
Date registered: Jan 2005
Vehicle: 1992 W126 300 SE
Quoted: 2 Post(s)
No one has given you the prime advice-Don't force it!
You haven't given any clues as to how old/worn the lock/key are?
If age/wear are a factor, a lot of gentle giggling with pulling/pushing the key may just free it.If it does,get it replaced immediately-You rarely get second chances with these things.
deathrattle is offline
post #7 of 11 (permalink) Old 02-20-2006, 06:22 AM
BenzWorld R171 Host
ianx, manchester's Avatar
Vehicle: SLK350
Charlee - 2/20/2006 3:01 AM
if you have one of the new transponder type keys (no blade) this sounds like a failed EIS. expensive to fix i'm afraid. Do a search it has been covered before.
ianx, manchester is offline
post #8 of 11 (permalink) Old 02-20-2006, 08:50 AM
asianml's Avatar
ianx, manchester - 2/20/2006 8:22 AM
I was thinking that.
Charlee, what year is your E320? My Uncle had this happen with his W210 E320.
asianml is offline
post #9 of 11 (permalink) Old 11-28-2014, 07:23 PM
Date registered: Nov 2014
i drop my key in water and now I got into my car this morning and the ignition key doesn't turn
jude 1111 is offline
post #10 of 11 (permalink) Old 11-28-2014, 11:43 PM
Date registered: Jul 2005
Quoted: 975 Post(s)
The key can possibly be salvaged. Pull the batteries out.
Let the key dry by setting it on some plain uncooked rice in a sealed container. In a day or two with new batteries it may work again.
I know the keys are expensive, but all of the cars with smart keys should have two keys so that if on gets damaged or just wears out the car is not sitting for several days while a new key is gotten from a dealer.
Noodles is offline
