W123 indicators not flashing - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-18-2006, 01:14 AM Thread Starter
Date registered: Feb 2006
Vehicle: 1981 300TD
The indicators click once when activated and no more (do not flash). The hazard (warning) indicator still works when the button in the centre console is pressed, If, as I suspect, the flasher unti needs relacing, is this contained in the hazard switch body and the whole unit needs replacing?
JRuss is offline
post #2 of 6 (permalink) Old 02-18-2006, 01:06 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
RE: W123 indicators not flashing
Your year and exact model, please.
flyboyike is offline
post #3 of 6 (permalink) Old 02-18-2006, 01:19 PM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Drop down to the 123 posts. Most of the flasher unite are under the hood. It is a plug-in unit. Are all your bulbs good and grounded? Check your fuse box for a diagram and then replace the fuse even if it looks to be okay. It's a good idea to clean up the fuses anyway if the car sits out. [:D]
Ed Mclass is offline
post #4 of 6 (permalink) Old 02-18-2006, 03:07 PM Thread Starter
Vehicle: 1981 300TD
1981 300TD - Is this enough?
JRuss is offline
post #5 of 6 (permalink) Old 02-18-2006, 03:32 PM
flyboyike's Avatar
Quoted: 69 Post(s)
JRuss - 2/18/2006 4:07 PM
It's enough. Looks like you have the same setup as my car (1979 280E), which means that you will have to replaced the whole thing. The relay is part of the switch on our cars.
http://www.autohausaz.com/search/productx.aspx?sid=ie54cv45ax1xd1e4dcjg2455&makeid= 800016@Mercedes&modelid=1194308@300TD&year=1981&ci d=18@Electrical%20%26%20Vacuum&gid=3396@Hazard%20W arning%20Relay
post #6 of 6 (permalink) Old 02-18-2006, 03:36 PM Thread Starter
Vehicle: 1981 300TD
Thanks, that was my suspicion as the single click comes from the hazard switch - only wasn't sure why the hazard lights (all 4 indicators) are still flashing fine?
JRuss is offline
