Range of smart key for opening or locking doors - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 02-08-2006, 02:34 PM Thread Starter
Corkscrew's Avatar
Date registered: May 2005
Vehicle: 2009 BMW Z4, 2005 SLK 200, 2004 S 280
I know that I can lock or unlock my car using the smart key from at least 200 feet away by pushing the button....and it can do it through an intervening glass window. Can it also see around corners in a parking garage?
But, how close to I have to have the smart key to the car before I can unlock the car by just touching the door handle? Or, lock it by touching the black button?
Corkscrew is offline
post #2 of 14 (permalink) Old 02-09-2006, 05:51 PM Thread Starter
Corkscrew's Avatar
RE: Range of smart key for opening or locking doors
Has no one had this problem? Well, this issue? Or this question?
post #3 of 14 (permalink) Old 02-09-2006, 05:54 PM
asianml's Avatar
Date registered: Sep 2005
You have Keyless Go I'm assuming?
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
post #4 of 14 (permalink) Old 02-10-2006, 06:53 AM Thread Starter
Corkscrew's Avatar
asianml - 2/10/2006 8:54 AM
Yes.
post #5 of 14 (permalink) Old 04-07-2008, 09:55 AM
Date registered: Apr 2008
Remote Key Range.
I have the same issues as well. I recently purchased a new key from the dealership. The old keys wont work at all or should I say, they would start the car but wont, lock/unlock the doors. The new key would atleast lock/unlock the doors and start the car as well, but I have to hold the key within inches of the door handle.
Can someone tell me what could be the issue and how should I fix it, please?
benzfan74 is offline
post #6 of 14 (permalink) Old 04-07-2008, 10:51 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
You could tell which car you are talking about. In any case battery power is needed on the keys for opening/closing doors while starting the car works without any battery within the key. So it could be a dead battery in your old key.
But if a new key also works poorly, it sounds like the RF receiver antenna was not working well. But your car may not have any.
Anyway this is quite different from what Corkscrew asked. When opening doors with the remote, the key (in his car) sends an RF signal that can even pass corners (radio wave reflections) or passes through walls (that are not metal). But the keyless go key works a bit opposite way, the range is intentionally very limited, the car would need to detect if the owner is on one or the other side of the car, or at the rear.
Diesel Benz is offline
post #7 of 14 (permalink) Old 04-07-2008, 11:06 AM
Kajtek1's Avatar
Quoted: 1250 Post(s)
I think Corkscrew is talking about smart CARD, or whatever the new technology is called.
We, normal folks don't have it our cars. It was introduced about 4 years ago
Kajtek1 is offline
post #8 of 14 (permalink) Old 04-07-2008, 11:14 AM
Date registered: Mar 2008
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
Regardless, your RF range for unlocking and locking the door with the remote is around 200 ft, through walls around wall ets. Your IR signal for rolling the windows up and down is about 30ft but it must be aimed at the IR reciever on the door. Your KG signal(for unlocking and locking by touching the handle) is limited to within 2-3ft of the driver or passenger door or trunk.
kyle21nluvnit is offline
post #9 of 14 (permalink) Old 04-07-2008, 11:54 AM
Quoted: 39 Post(s)
Yes, that is still Keyless Go. It was an old post, probably talking about the V220 where it could be the card. Actually now the card has been changed to a smart key that looks the same as the standard smart key. You can even use it like the standard key in the ignition slot. A plastic cap can be put to the slot and then it works without the key in place. The cap works as a start button instead of the button at the gear stick like on older models.
post #10 of 14 (permalink) Old 11-03-2011, 07:41 AM
fjc335's Avatar
Date registered: Oct 2011
Vehicle: 2005 CLK 320 Cabrio
I was test driving a 2005 clk cabrio and the remote can only unlock door from the passenger side. When standing on the driver side, it doesnt work and i had to walk over to the passenger to unlock the doors. Is it the battery or something wrong on the driver side.
fjc335 is offline
