"Lamp Light" Defective - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-01-2006, 09:06 PM Thread Starter
Date registered: Feb 2006
I had my 97 S500 checked out for a warning light indicating that I had a bulb out and they could not find anything. I did not take it to a Mercedes mechanic though.
This only happens when I apply the brake. Any suggestions? Is it a faulty brake light and is it easy to replace myself?
Thanks everyone.
Sam
samandtina is offline
post #2 of 3 (permalink) Old 02-02-2006, 10:40 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
RE: "Lamp Light" Defective
If it only comes on when you apply the brake, then it's the brake light. That can only be checked with the ignition on. The bulb holder is a weak point in the 210 chassis for sure - not sure about yours. The light may or may not be burned out. Have someone step on the brake pedal while you jiggle the bulb to see if you can find the sweet spot to make it work. Also check the third brake light.
Len
sokoloff is offline
post #3 of 3 (permalink) Old 02-02-2006, 11:54 AM
Be sure to check the upper middle lamp light also.[:)]
starcar126 is offline
