Trunk Problems - how do I get in !!?? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 01-29-2006, 03:10 AM Thread Starter
Date registered: Jan 2006
I have a 1999 Mercedes C230 Kompressor 4 door saloon. It has been stood a while - when I went to it yesterday the battery was flat, unfortunately, the battery is in the trunk and I cannot open it with the electonic release. Furthermore, the manual key in the electronic fob will not open the trunk lock, obviously I need to get into the trunk to get at the battery to charge it - an ideas would be greatly appreciated, cheers.
Ken Caskie is offline
post #2 of 12 (permalink) Old 01-29-2006, 03:32 AM
conleycrew3's Avatar
Date registered: Nov 2005
Vehicle: Mercedes E200 black. Mercedes 300ce - sold.
Send a message via MSN to conleycrew3
RE: Trunk Problems - how do I get in !!??
if you have breakdown cover, call the rac, aa or green flag.
have you tried getting in through the rear seats?
merc 300 ce, amg bodykit, 17" amg alloys, lowered, Azul Azurite blue 98000 on the clock and two tone leather!!! (click a picture to see a larger image)
<a href='http://putfile.com/pic.php?pic=1/2703595437.jpg&s=x4' target='_blank'><img src='http://x4.putfile.com/1/2703595437-thumb.jpg' alt='Click to enlarge.'></a><a href='http://putfile.com/pic.php?pic=1/2704020128.jpg&s=x4' target='_blank'><img src='http://x4.putfile.com/1/2704020128-thumb.jpg' alt='Click to enlarge.'></a><a href='http://putfile.com/pic.php?pic=1/2704071368.jpg&s=x4' target='_blank'><img src='http://x4.putfile.com/1/2704071368-thumb.jpg' alt='Click to enlarge.'></a><a href='http://putfile.com/pic.php?pic=1/2704043136.jpg&s=x4' target='_blank'><img src='http://x4.putfile.com/1/2704043136-thumb.jpg' alt='Click to enlarge.'></a><a href='http://putfile.com/pic.php?pic=1/2704032128.jpg&s=x4' target='_blank'><img src='http://x4.putfile.com/1/2704032128-thumb.jpg' alt='Click to enlarge.'></a>
conleycrew3 is offline
post #3 of 12 (permalink) Old 01-29-2006, 08:47 AM
Date registered: Feb 2005
Vehicle: '03 CL500,& '07 GL450
I recall a suggestion from a poster who purchased a device that would send a small charge through the cigarette lighter. The key would be in position "2" to energize the circuit. The owner then used the electronic remote key to unlock the trunk. Try a search for "trunk problems","trunk locks",etc.
Goor luck. [8D][8D][8D]
reddog is offline
post #4 of 12 (permalink) Old 01-29-2006, 08:52 AM
reddog - 1/29/2006 4:47 PM
you can buy a jump starting kit that works from the cigarette lighter sockets.
fairly cheap too. halfords sell them at around twenty quid i think
post #5 of 12 (permalink) Old 01-29-2006, 10:48 AM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1346 Post(s)
With old battery shorten the cigarette jumper might not work. Some models have 500 amp-rated jump post under the hood. Other option would be to get to the fuse box, eliminate the trunk circuit and jump it there.
Kajtek1 is offline
post #6 of 12 (permalink) Old 01-31-2006, 01:33 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
I think that person finally figured out if you turn the key to 90 degree and push it will unlock. This of course depends on the lock not being screwed up. MB locks have the valet feature, you lock the tunk with a key and the release wont work. On a 99 there is a post on the front fender I think, call MB Road Aid, tell them you have a dead battery = No charge, unless it is bad then it is $150 and they come out with the radio code also, on a 99 its time
Peter Guenther is offline
post #7 of 12 (permalink) Old 02-04-2006, 06:40 PM
Date registered: Feb 2006
Spray WD40 in the trunk lock then use the metal key and try to turn couple times.
Tony500 is offline
post #8 of 12 (permalink) Old 02-04-2006, 06:57 PM
peter811's Avatar
Vehicle: 1984 300D
Do not spray WD40 in the Trunk Lock, because you will mess up the lock mechanism. I suggest you get a spray bottle of lock lubricant from a locksmith.
peter811 is offline
post #9 of 12 (permalink) Old 02-05-2006, 11:19 AM
peter811's Avatar
Vehicle: 1984 300D
CAll the mercedes benz phone# in your glove box, they should beable to send someone out to help you with your car.
In my W115, and my W123 the phone# was in my glove box.
I have heard stories of how mercedes would send out mechanics to stranded motorists and the service is free of charge.
peter811 is offline
post #10 of 12 (permalink) Old 02-05-2006, 12:34 PM
Date registered: Jul 2005
Quoted: 1147 Post(s)
peter811 - 2/4/2006 8:57 PM
100% in agreement. It will eventually gum up the assembly.
There is a product called Lock Eez and all hardware stores carry it. It is designed just for locks.
Noodles is offline
