Trunk Problems - how do I get in !!?? - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 02-06-2006, 06:15 PM
Date registered: Dec 2004
Vehicle: 1990 500SL
Send a message via AIM to 90-500SL Send a message via Yahoo to 90-500SL
RE: Trunk Problems - how do I get in !!??
yes i know in the USA mercedes will send out a ML to jump your car for free no charge no matter what year your car is. i've had it done twice in my 1990 500Sl in the last two years.... darn dome lights...
1990 500SL....
143,563 miles and still counting... well not anymore.. dead Odometer.....
Check Out my Gallery!
90-500SL is offline
post #12 of 12 (permalink) Old 02-12-2009, 09:32 AM
Date registered: Feb 2009
How to open, pop the trunk on a Mercedes with a dead battery. I jump start cars on my job. Last week we had an older, bigger Mercedes with a dead battery, the driver could not open the trunk with the key. I think he ended up having the car towed. Later I googled this problem, and the google indicated that you can power the system by placing a 12 volt source on the starter.
Last night I got a call with a customer with a Mercedes C230. Same thing. Dead battery, trunk would not open with key.
I was not going to go under the car to try and find the starter. However, I found a small plastic cover hiding some electrical terminals located over the drivers fender under the hood.
I took the cover off, tested one of the terminals for voltage and got a 5 volt reading. I hooked up my portable jump start unit to the terminal with plus to the terminal and negative to the engine. The driver then used his remote and the trunk popped up? Mission Accomplished.
Mike Schmitt is offline
