Rear Seat Belt Caution - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-25-2006, 04:08 PM Thread Starter
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2010 S550
Quoted: 227 Post(s)
I have a 2005 S500, but because this situation arose from the design of the rear seat child restraint system, it is probably applicable to other models and years.
First, what happened was my own fault. My dealership offered to try to get the situation fixed under warranty - but very simply, it was my own fault, so I did not request that they do. [:(]
For years I have secured a medium-sized pet carrier in the back seat by looping the rear seat belt on one side or the other through a handle at the top of the carrier, tying it fairly loosely. Typically, the load has been firm enough when traveling this way that looping the belt through the top was sufficient.
However, recently there was nothing else to brace the carrier, and I looped the entire seat belt around the carrier, and then looped the top portion of the belt through the handle. The belt had more tension on it this way, and the knot pulled tight (against the buckle). When I got where I was going, I could not get enough slack to loosen the knot. Each time I tried, the belt retracted a little more. [:0]
I had to cut the handle of the carrier, hoping to loosen tension and untie it - but the takeup reel kept retracting, and would not release to provide any slack (as the front belts do). [xx(]
Bottom line is, the belt retracted with the knot against the upper panel (where side air bags are). I took it to the dealer, hoping that there was a release device on the takeup reel - that would allow me to get some slack and untie the knot.
There isn't. [xx(]
$600 to replace the belt (parts + labor). [V]
The rear belts must be nearly fully fed back into the takeup reel (I would estimate about 80%) before they will release and let out again, once thay have locked. They allow a little slack a little slack, but not nearly as much as the front belts (which only need the tension released slightly in order to feed out again).
So, don't tie knots in your seat belts. That's not how they're designed to be used. Duh! [^]
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #2 of 2 (permalink) Old 01-26-2006, 07:00 AM
Andrzejek's Avatar
Date registered: Jul 2004
Vehicle: 00 C-230, 04 C-240
RE: Rear Seat Belt Caution
Expensive lesson learned! I'm constantly swapping two child seats between wife's & my car, & I'm always very careful with the belts. Your story confirms my caution.
Andrzejek is offline
