How do I turn on my fog light? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 01-22-2006, 10:13 PM Thread Starter
Date registered: Jan 2006
Vehicle: 1982 240D
Send a message via Yahoo to xoc8
xoc8 is offline
post #2 of 13 (permalink) Old 01-22-2006, 10:26 PM
rcltrh's Avatar
Date registered: Nov 2005
Vehicle: '01 ML-430/'96 C220/'05 Lexus RX330
RE: How do I turn on my fog light?
Not sure but on my 96 C220 you pull out on the light switch after turning it to the headlights on position. I click out is rear brakelight on driver's side (called rear fog) 2 clicks out is that plus the front foglights. Headlights have to be on low beam.
'96 C220
'01 ML-430
'05 Lexus RX-330
rcltrh is offline
post #3 of 13 (permalink) Old 01-22-2006, 10:46 PM
slightly creased
420 SE's Avatar
Date registered: Sep 2005
Vehicle: 1988 420 SE; 2015 ML 400
Quoted: 139 Post(s)
It should be the other way around, 1 click out for front, 2 clicks out for front and rear, unless your switch has had some mod?
Ross
OzBenz
beware of fundamentalists
420 SE is offline
post #4 of 13 (permalink) Old 01-22-2006, 10:57 PM
BenzWorld Elitist
Marsden's Avatar
Vehicle: Mercedes-Benz
Quoted: 453 Post(s)
Now be sure and tell him how to turn it OFF [8D]
Marsden is offline
post #5 of 13 (permalink) Old 01-22-2006, 11:31 PM
Syracuse315's Avatar
Date registered: Jan 2005
Vehicle: '86 190E 2.3L
Marsden - 1/23/2006 12:57 AM
Hammer to the switch or light bulbs..I guess the seller of your car forgot to tell you they were 1 time only fog lights...
If it jams, force it. If it breaks, it needed replacing anyway.
1986 190E 2.3L 135,000mi
Syracuse315 is offline
post #6 of 13 (permalink) Old 01-22-2006, 11:44 PM
peter811's Avatar
Vehicle: 1984 300D
turn the headlight switch all the way to the right, then pull the switch out. Make shure that your high beens are off or else you won't beable to turn on your fog lights.
peter811 is offline
post #7 of 13 (permalink) Old 01-23-2006, 01:26 AM
peter811's Avatar
Vehicle: 1984 300D
you may need to get a new knob, but DO NOT GLUE THE KNOB BACK. Just push it back on. I recommend that you go to a junk yard and get a used knob. I think it should only cost you about $3 or less. If you were located in the Houston area I would just give you a replacement knob at no charge.
peter811 is offline
post #8 of 13 (permalink) Old 01-23-2006, 11:00 PM
TheRazz's Avatar
Vehicle: 1984 280SEL AMG
Send a message via MSN to TheRazz Send a message via Yahoo to TheRazz
Mine works, but the knob pulls off, I just apply a small bit of extra twist then pull, and they turn on... Also mine work regardless of high/low beams [:)]
1984 280SEL AMG
1984 F250 Diesel
1992 F.O.R.D. Explorer
1997 F.O.R.D. Expadition
1972 F250 (57K origanal)
1980 Suzuki GS750ET
Razz
I reject your reality, and substitute it with my own (Mythbusters)
TheRazz is offline
post #9 of 13 (permalink) Old 01-23-2006, 11:04 PM
Too bad, both my fog lights are busted..stupid deer and blown light..good thing my euros gte here in 2 days!!!
post #10 of 13 (permalink) Old 01-24-2006, 12:03 AM
SaleenS7's Avatar
Date registered: Apr 2005
Quoted: 2 Post(s)
TheRazz - 1/23/2006 10:00 PM
Yeah my foglights works with high beam on too. It should be like that for all W126s.
SaleenS7 is offline
