Problem with my 1997 c230 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-19-2006, 10:11 AM Thread Starter
Date registered: Jan 2006
Vehicle: 1997 c230
Send a message via AIM to TheProfit718
Ok, i have a 1997 c230 with 112,000 miles on it. i'm having a problem with the cars alarm or ignition. well actually i dont know thats why i'm writing this.
sometimes my car won't start. it starts up then it juss stalls as if a sensor is telling it to shut down. whenever i do get the car to start it drives beautifull. if its on it wont ever stall or turn off.
i've noticed that this only happens when i lock my doors, using the infared key. if i never lock the door, when i get back in the car starts perfect. but if i lock the doors, when i get back in the car dosnt turn on. i play with it for a while and eventually it turns on but does anyone have an idea of what it can be?
TheProfit718 is offline
post #2 of 4 (permalink) Old 01-19-2006, 11:27 AM
Always Remembered RIP
Vehicle: 220SEb coupe & 500SL
RE: Problem with my 1997 c230
You may get a better response if you post in the W202 section below.[:)]
- Jason
'61 Mercedes 220SEb coupe
'64 Land Rover IIa
'83 Mercedes 500SL
heckflosse_uk is offline
post #3 of 4 (permalink) Old 01-19-2006, 12:00 PM Thread Starter
Vehicle: 1997 c230
thanks alot i'm kinda new to this whole thing
post #4 of 4 (permalink) Old 02-03-2006, 11:52 AM
bishopjr's Avatar
Date registered: Nov 2005
Vehicle: 1997 C230 K sport
When you use the infra-controler to lock your car,this triggers a shutdown valve to close the fuel feed to the engin.
So by the looks of things when you open the locking system again (with the infr-controler)for some reason this valve is jaming and so the engine won't start.
When you keep pressing the controler a few times it may be reliving the valve.
check it-
Hope this is usefull,
bishopjr is offline
