LQQKING FOR NEW OR USED MBZ SMART KEY REMOTES, ANYONE!!!!!!!!!!!!!!! - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 01-16-2006, 07:49 PM Thread Starter
gboctor's Avatar
Date registered: Jan 2006
Vehicle: 2002 CL-500
If you have a set, CAN THEY BE RE-PROGRAMMED???? THANKS.
gboctor is offline
post #2 of 21 (permalink) Old 01-16-2006, 10:42 PM
benzboyz's Avatar
Date registered: Jun 2005
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
RE: LQQKING FOR NEW OR USED MBZ SMART KEY REMOTES, ANYONE!!!!!!!!!!!!!!!
smart keys are specifically programmed for one car, it is married to the engine control unit and ignition switch (EIS). and can only ordered with the correct VIN.
in the case of vehicle with no steering lock the key is also programmed on the gear selector lever (ESM).
And in ordering rheft related parts like smart keys, engine control unit,esm,eis etc. you need to provide proof of ownership with the dealer.
benzboyz is offline
post #3 of 21 (permalink) Old 01-17-2006, 08:22 PM
MrBenz55's Avatar
Vehicle: CLS 55 AMG, One Day !
Actually ALL mercs are like that, without the correct car the key is just useless !
MrBenz55 is offline
post #4 of 21 (permalink) Old 01-17-2006, 09:36 PM
1996_S500's Avatar
Date registered: Nov 2005
RE: THATS NOT TRUE
MrBenz55 - 1/17/2006 8:22 PM
THATS NOT TRUE. on the w140, r129, w210, as well as other models, there is a remote control as well. You can get someone else' and just change the key and program it yourself. By simply holding down the one button while twisting it up and down in the ignition.
Benzboyz is right about the smart keys though...
They are programmed to the engine control unit and ignition switch.
My cars:
BLACK 1996 S500 (W140) - Sold
BURGUNDY 1989 560 SEL (W126) - Sold
____________________________________________
1996_S500 is offline
post #5 of 21 (permalink) Old 01-17-2006, 10:26 PM Thread Starter
gboctor's Avatar
RE: THATS NOT TRUE
1996_s500 - 1/18/2006 12:36 AM
T H A N K Y O U ! ! ! ! ! ! !
That is what I had heard through the grapevine, however I have never known anyone to actually know anything about this one way or the other.
Here is my delima!! I have a 2002 CL-500(w215). I broke my smart key and I need a new/used one. Can I buy those being sold on eBay?????
P L E A S E H E L P ! ! ! ! ! ! !
gboctor is offline
post #6 of 21 (permalink) Old 01-17-2006, 10:40 PM
1996_S500's Avatar
gboctor - 1/17/2006 10:26 PM
i'm not completely positive about buying one off of eBay. either way, you have to go to the dealership, because only they can program it.
You may be able to buy one off of ebay, and give it to your dealer to program. You will also have to get another key blade, and get that cut by the dealer. I would say, get one of ebay, and then tell your dealer to put in a new key, cut it, and the program the key to work with your car. I am pretty sure this will work.
You could also go to the dealer and get a completely new one from the dealer, but it will cost you around $250-300. Programmed and cut key. This will definately work, but will be expensive.
Although, i am not sure if any of this will work. I am simply trying to help you.
-1996_S500
My cars:
post #7 of 21 (permalink) Old 01-18-2006, 09:43 AM
asianml's Avatar
Date registered: Sep 2005
I'm pretty sure SmartKeys can't be bought off of eBay and then reprogrammed.
If they can't do it for my M'Ls switchblade key, then I'm pretty sure they can't with the SmartKey.
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
post #8 of 21 (permalink) Old 01-18-2006, 11:15 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
Smart keys CAN NOT be reprogrammed! They have to be ordered and the factory keeps track of the codes. There are only 24 combination of codes for any car.
The computer has to be changed and it comes with a learning key. A remote is either orderd as a additional or eplacement. The additional uses the next code for that car, the replacement wipes the first one smart keys were intoduced with the very late 140s, and 210s. Typically two codes were used for the remotes, one code was used for the emergency key. The remote is infrared for the doors and inductive for the ignition, so if the remote battery goes bad you can still start the car. the replacement remote talks to the car and can take up to 45 minutes before it will start and keep the car running.
The only use for smart remotes is if you want to impress your friends and to use the housing as a replacement. Some lat 90s could be coded by the dealer, but I think it was activation not reprogramming. The aiming of the remote and turning on the ignition was to resync not recode, and there were different proceedures.
There is a 10 page document that discusses "smart key" disabling, clean install, and the role of the factory.
Peter Guenther is offline
post #9 of 21 (permalink) Old 01-19-2006, 08:06 PM Thread Starter
gboctor's Avatar
Peter Guenther - 1/18/2006 2:15 PM
If I may ask, where did you gather the above information?
gboctor is offline
post #10 of 21 (permalink) Old 01-19-2006, 08:47 PM
samhmbz's Avatar
Date registered: Oct 2004
Vehicle: 164.125 163.175 Previous W211MOPF-W211C209W202W124
Some more info here.........
http://www.benzworld.org/forums/foru...223278&posts=6
Peter is correct you cannot reprogram or code or in any way get a smart key for a particular vehicle to work with any other vehicle.
If you dont want to deal with programming the smart key order a "additional" key(considering you still have tracks avaliable).
Although this will not cancell out your missing or lost key.........
Sam
Free maintenance ? buy a Bimmer......
samhmbz is offline
